Choosing cars
Choosing cars
Guys,
its time to move up, I need to upgrade my ride from NTC3 to either a Mugen MTX-4 or the Kyosho V-One RRR help me choose between the two cars any cons and pros between the 2 cars.
Thanks.
Thanks.
Mate,
I just got a MTX4 and it is awesome, it is soo smooth compared to my FW05rr its no longer a struggle to go around the track fast!.
I guess what you have to look at is support in your area. The kyosho was a good car but the support was really poor, as i would have to wait ages to get new parts.
For me it was between the serpent 720 and the MTX4 well you know which one i chose!., purely based on the availibilty of parts.
Originally Posted by BeBop
Guys,
Thanks.
Thanks.
Good luck.
CHOOSING THE RIGHT CAR
I'm running the kyosho rrr and so far its the one for me the car has a large sweet spot parts are relatively cheap in price .
As every one has stated before you need to realy consider which one is supported in your area, parts support is very important. If i had to choose i think i would go with the world champ, its hard to beat a mugen, dependable, strong, and simple! I carry both, for cheap! But i race only mugens!!!!
In the end the choice is up to you!
check to see what the other racers are running at the races that you are planning to attend that way if you have a problem or can't get the car to work you will be able to ask for help on setting up your car if you are the only one with that kind of car you are basically on your own if you break something on your caar and you are the only one running it you either have to carry your own parts or go home if you are running the same as other racers then you have a chance of getting spare parts that being said it is probably a toss up i run a mugen that is three years old and can usually find parts at the races that i attend good luck
hmm
check to see whats being run at your track & scout out the car see what kinda issues are being had find out what car you can run out of the box also check the durability factor also clutch hope to see you winning soon
