new ofna DM1 pics and thoughts :):)
#826
Send them an email [email protected]
Anyway, I sent them a mail, and will post their answer.
The price is expensive, but man it's hard finding parts for the DM-1.. You have to track down every little bit, and there are different part numbers for the same thing depending on which car it comes from (1/8 or 1/7) as far as I can tell.. Kind of a pain..
#827
alright..I will finally get to built my DM-1 Spec in about 2 weeks. I have been buying kits, parts, electronics, and other needed things so I can get it ready and out racing. Although I enjoy nitro i went with the tekno brushless conversion. Anyone have any recomendations on what i should watch out for once I build my DM and start testing it?
I should have everything I need to get it up and running but we shall see...man am I ready to get my hands on this car! I plan to post many pictures and videos to share...
I went with the 2 speed, clutch and mechanical brakes and love it.
Here is my build if it helps any:
http://www.rccoh.com/rc.how-to/dm-1....onversion.html
#829
What electronics are you going to use? If you are using a sensored system, you will probably need an extended sensor cable, but other than that, it's a simple build.
#830
#831
#832
#833
Ofna's reply:
"Most of it will work. The 2 speed shaft will not. The clutch bell may not. Sorry I do not see the OFNA part number.
Best Regards,
Dave xxxxx
OFNA Racing"
Best Regards,
Dave xxxxx
OFNA Racing"
#835
Clutch bell with 14t and 18t. Pretty steep....
#836
OFNA black shirts for sale on For Sale Thread.
http://www.rctech.net/forum/r-c-item...rts-black.html
#837
Gearing
How much can I go up or down on the 1st speed before I have the change the gearing on the 2nd speed. I am looking for faster accelaration any sugestions welcomed. Thank you.
#838
for example.
gear 1st 2nd
cb 14t 18t
spur 49t 45t
total 63t 63t
now i have broke the rule of the difference of four and even the adding to same total by + or - 1 tooth and i have never had problems.
for example i have ran in my dm1 with lrp30
in the clutch bell 15t/20 and in the spur 49t/44t which gives you better take off same top end.
also have tried 16t/21t and 49t/44t and gives you both a little better take off and a little more top end. but i think you really need a power house motor to pull this gears good.
hope this helps
break the rules and break parts = learn experience
#839
Gearing
Thank you awsome info.
#840
So, finally got out to the local club track.. WOW!!! It was FUN. Huge track..
Gearing and tires aren't ideal, and this was my first time ever running on this track..
First, an onboard vid that is a bit long and hectic.. But hey, wanted to try it...
1/7 DM-1 Sport version with Porsche Carerra GT body, Mach 427 engine with 2063 pipe and Fioroni slider clutch, Hitec 5955(actually, the Tower version of it..) on steering, and Spektrum H6040 (identical to Savox 1258) on gas/brakes..:
http://www.youtube.com/watch?v=WJfOhSb5Nug
Got another one from the drivers stand coming up in a second.. That track is HUGE...
So, normal vid of track and DM-1 from drivers' stand..:
http://www.youtube.com/watch?v=UmWXUt4cqdo
