new ofna DM1 pics and thoughts :):)
#331
I was surprised too! However, let’s see what they say after they get the engine. I was using 15% fuel In the brake in phase and 30% on the track. The one thing I notice is it sounded like if it was too rich even if I lean it up to 2 ½ turns. However, the engine stall when I hit full throttle then I richen a bit until the engine didn’t do it anymore, temperature was find. The one thing that I am kind of confused is that the inside of the engine where the crankshaft is located has no scratches. Which is odd because if this happen when idle or full throttle it would leave some marks on the inside walls.
#332
Hi,
Help I am putting together my DM1 Pro kit,and installing a .21 VSPEC I had laying around.And the pipe JP3 seems to hit the gas tank when its not in the spring mount at the tip of the pipe.Now I could install the mount and force it alittle bit and it wont hit.But then its not a square tight seal where the pipe attaches to the header???? What do you think?
Thanks Pete
Thanks Pete
#333
Hi,
Thanks Pete
Thanks Pete
#334
Thanks! How did you bend it? Heat?
I will probably go to the LHS to get the header since this is out of my buggy.And dont want to make it fit in this car and not the buggy.Going to get a Picco .28 for it when they come in.
Do I really need to put more bearings in the front of the bell? If so how does the washer for the bolt not hit the bearing since it wont be resting on the crank anymore?
ANd these shocks do come with oil right? Hard to tell.Guess I could pull one off.
#335
#336
do you have the part # for sg shaft extension kit, what brand?
thanks'
thanks'
#337
TORNADO RACE
THERE IS A CLASS FOR THE DM-1'S, IGT'S ETC. THIS SUN. AT 301 RACEWAY AT THE TORNADO RACE THIS WEEKEND
#340
everyone is getting ready for this weekend and sat. is bad for a lot of guys
#342
Picked up a LRP .30 today. Still need to get a pipe though. Planned on using the stock exhaust set-up but the manifold is too large.
#343
Here's a few pics
#344
Suspended
Sweet pics. Just a shout out to the DM1 Crews. Max Velocity Racing has the full Carbon Fiber kits for the DM1. I almost knocked a pound off my car weight with the parts and removing the unneeded stuff. Check it out. www.maxvelocityracing.com
#345
Nice CatDaddy that car should be wicked fast!!!!
