CHECK THIS OUT 1/36 Micro-T
Team Losi MICRO-T! 1/36 scale!
Latest from www.teamlosi.com, as spotted at www.horizonhobby.com. This thing looks awesome!
1/36 Micro-T Stadium Truck RTR
Key Features
Fully independent suspension with friction dampers
Differential-equipped transmission
Powerful, pre-installed micro motor
Included Ni-MH battery pack with portable alkaline automatic peak charger
Team Losi 27MHz radio system
Electronic Speed Control with Reverse
High-traction rubber tires on pre-mounted on durable nylon wheels
Includes 8 AA heavy-duty batteries for transmitter
Includes 8 AA alkaline batteries for charger
Overview
Team Losi is out to take RC to every level with the Micro-T. The Micro-T is the smallest RTR that Team Losi has ever offered, coming in at just under 5 inches long. But just because it’s small doesn’t mean it skimps on performance. Packed with a Ni-MH battery pack, independent suspension, differential equipped transmission, automatic peak charger and 27MHz Team Losi radio system, the Micro-T has the speed and handling to tackle everything from the tabletop to the tile. Take it with you anywhere you go and satisfy your need for speed with the Micro-T.
Specs
Type: 2WD Stadium Truck RTR
Scale: 1/36
Length: 4.5 in (114mm)
Width: 3.5 in (89mm)
Wheelbase: 3 in (76mm)
Weight: 3.4 oz (96g)
Chassis: Composite tub
Suspension: Independent
Drive Train: 3-gear transmission w/gear diff and slipper
Tire Type: rubber multi-pin rear/ribbed front
Motor or Engine: Micro Electric
Speed Control: Electronic Forward/Reverse
Radio: 27MHZ AM Pistol
Servos: Sub-micro
Batteries: 4.8v, 150MAH NiMH (included)
Charger: Peak (included)
Wheel Size: 0.75 in (19mm) diameter
Kit/RTR: RTR
Shock Type: Coil-Over Friction Dampers
Body: Factory-decorated Stadium Truck
Ball Bearings: BB-Equipped Transmission
Needed to Complete
Nothing.....everything's included!
Key Features
Overview
Specs
Scale: 1/36
Servos: Sub-micro
Kit/RTR: RTR
Needed to Complete
Now there's an office racer! Kind of spendy though for what it is...
I gotta have one!!! anybody know when they are hitting the shelves?
Hopefully the actual "street price" will be a little lower than Horizons list of $80
At around 5" long, it looks ubber neat
brushless anybody?
Originally Posted by ProudSavageOwnr
brushless anybody?
Comes with a 4 cell nimh pack 150mah. I have some LiPo packs that are probably small enough!
Originally Posted by vtl1180ny
Good luck... Looks like it charges like the microsizers....
and yes if u got the AM modules u can control this little badboy!
Trader Rating: 31 (100%+)
anyone found any off body pics yet?
I was reading stuff over and the rc car magazine forum and people are already talking about upgrading this thing with a brushless. Isn't that overkill though? This thing is small so isn't it really more a novelty item to have fun with inside the house when you can't be out with the bigger badder stuff? In which case having insane speeds will probably mean lots and lots of crashing. And why hasn't Losi shown any pics with the body off? Is it possible this thing won't be upgradable? Or maybe they just don't want to give the competition any ideas?
