Team Corally RDX
Old 10-10-2006, 04:45 AM
Default Team Corally RDX
Team Corally RDX
I have a Corally RDX with aluminum A arms front and rear, with aluminum steer blocks. The car comes with the 2.0 mm chassis as well as the stock 2.9 mm chassis. I also have an extra 2.0 and 2.9 mm chassis. the car also comes with 3 extra diffs (used) and 2 spools and 1 one-way. I also have many parts that are used but in good condition such as: aluminum a arms, 2 deg c hubs, 6 deg c hubs, 4 extra shocks (one is missing a shaft), rear hub carriers and a set of new cs-27's by take off. I have the Corally weight that bolts to the chassis, drive shafts, turnbuckles, belts, sway bars, and misc screws. Basicly most of the parts you would need as spares.
I also have the following parts still NEW IN THE PACKAGE!
Front shock tower Corally part #79239
hingepin block #79120
set screws 3 packs #2210
hingepin insert #79123
wheel hexes (2 packs) #79140
a arms x hard (4 packs) #791094
front bumper #79330
MIP CVD's #79180
rear body post plate #79407
2 deg right c hub aluminum #79283
2 deg left c hub aluminum #79282
caps for drive shafts 2 packs #791898
MIP bones #79182
rear belt #79136
hinge pins #79110
toe in spacers .5 deg #79125
clips & shims #79115
o ring #1261
1.3 pistons #79223
Black spring set 2 sets #79230
And a new in package protoform mazda 6
I have pics that can be sent if you email me @ [email protected] , I am asking 350 dollars for all of what is listed. I do not want to separate this stuff. I will accept Paypal. Thank you for looking.
Bear55 is offline
New price 300 dollars shipped to your door!
Bear55 is offline
Old 10-10-2006, 08:05 AM
ejfin2's Avatar
You have email!
ejfin2 is offline
Old 10-10-2006, 10:00 AM
Pics sent!
Bear55 is offline
Old 10-10-2006, 02:18 PM
Car is sold pending payment.
Bear55 is offline
