motor fan
motor fan
hi will a 12volts 40mah brushless can be used as motor fan powered by a 3800ib battery? soldered through the speedo wire??
and whats the difference between the 5volts and the 12volts thanx
Your batts put out 7.2v so the 12v fan will not get enough power to work properly but a 5v fan will scream
