Losi 8ight building and setup
#3526
Trebor, plastic one's will work fine untill the aluminum one's are out. Im still using the plastic holder's with no problem. Just keep an eye out for any play on the rear diff. replacement are under 3 buck's,so its good to have a set as spare's regardless. Can't wait to fly up and do some racing...I hear your getting fast, Have to show you how the southern boy's drive..Dukes of Hazzard style....hehehe...
#3527
How much noise, if any, do your guys' clutch bell and spur gear make when rolling it on the ground by hand? I think I have my mesh set ok, (I jam one and can wiggle the other slightly producing a click) however it is really noisy rolling it back and forth. I'm thinking this is due to the fact that both gears are metal. In the past on other vehicles I've only ran a plastic spur and a metal bell.
Thanks,
-Mike
Thanks,
-Mike
#3528
Thanks,
-Mike
Thanks,
-Mike
#3529
Should it have any play in it? It seems if I make it so tight there is no play it is hard to move, but makes no sound.
Thanks,
-Mike
Thanks,
-Mike
#3531
Bohh- I usually use construction paper to space the bell and spur. kl
#3532
No Worries buddy, I am Ninja in the art of hacking .
#3533
OK Guy's Im curious, What's your "go to" tire and wheel combo for your 8? You know no matter what track you go to it's your favorite,or standard start up,set-up tire and wheel. Let's see what everyone's using. Me?, Proline Wabash wheel's and Crimefighter's in M2 compound.
#3534
Hey freefall I recently dismounted all my old wheels and put all my tires on the Losi rims. There's a lot of meat around the hub area and I think that the slightly bigger wheels get through the little chatter bumps better. Kind of like we used to do when we raced motorcycles on the ice. Bigger wheel on front gets through the breaking bumps better....
As for tires Crime Fighters are the tire I put on the most, but I have lots of others...
#3535
I always keep a set of Crime Fighters in my box, they work almost everywhere. I'm not saying that there is not a better tire for the particular track but crime fighter work pretty well at most outdoor tracks. I'm now also liking the GRP Grip. For clay indoor, Cell Blocks, Inside Jobs or if you have the money to blow Kyosho X-pins.
#3536
I tend to like the crimefighters also. I cant remember where I heard this but someone said use crimefighters in front, bowties in rear, or vice versa. Anyone try this?
#3538
#3539
Originally Posted by XMSRacing
I believe it was Truhe who dubbed that setup "Bowfighters". Haven't tried it yet - I plan on it this weekend though.
#3540
Casey Peck was the first that I know of to use/try the "Bowfighter" tire combo on 1/8 buggy.
