Losi 8ight building and setup
#256
any guys having any binding with the throttle linkage? I am having a hard time aligning the carb with the throttle linkage without getting enough side load on the carb barrel to cause binding on the throttle (not good)
#257
Two things!
1st, the rubber gromets under the throttle servo seem to have worked. I drove 2 tanks through it with no problems. I did, however, run a durability test(flew off biggest jump on track, straight into chain link fence post at 30+ mph, only cracked the hinge pin retainer... !)
2nd, I got my body back from the paint shop(father-in-law, he paints all my bodies) It turned out perfectly, I told him to try and match the box:
#258
Originally Posted by sand geek
Thanks!
So if I am waiting on my 3/3 block to come in can I just put a 1mm washer under the front mount of the diff case to make up for this?
I asked Drake this question and he said that you need .040 under the front of the gearbox to make the extra 1 degree. However he warned me that the driveshaft could be close to popping out of the center diff. I decided to just order the 3/3 plate
#260
I had to turn the ball end on the carb around to point to the back but that lined it up perfectly.
#263
Here is the best way to clean a pipe. Put the pipe in a slow cooker and cover it with antifreeze. Turn it on real low, and let the pipe sit in there for a couple of hours. It will take all the caked on crud right off the pipe and look nice and clean.
#264
You forgot the most important part....Don't let your wife know you borrowed her slow cooker!
#266
I 2nd both those comments Scuba and R40. Especially yours Scuba!!
#267
the more time i get on the new car the more i am likeing it! i am a good 1.5 sec a lap faster with the 8ight than i was with my xb8. i can also drive it more consistantley. and this is only with a few changes that were made. cant wait to get it tunes in even more and see what she will do.
#268
Originally Posted by H8W8IN
Hey Guys,
The new car is awesome! I have run about 1.5 gallons thru it. It handles the bumps like nothing that I have ever driven. Just floats right thru them. As far as people saying its overgeared , I dont agree. I have more acceleration than I have ever had. I had to open the needles to calm it down from what I'm used to. I cant wait to go the Futaba Challenge and Pro Series Finals!
Quincy Hughes
Quincy Hughes
I'm going to try going back to the stock ratio this weekend to see what happens.
You car looks great. What were you running for diffs? You told me but I forgot. I thought it was a little heavier than mine.
I aggree! The smoothest car I have ever driven.
Scott......Clean that thing will you???????
TEX
#269
5-5-7 , but I changed to 5-5-4
