Xray T2'007
#1187
Originally Posted by AChupp2
It seems a lot of people are using the Futaba S9550 servo for the T2 and T2 '007, what servo mounting whole does it use? The narrower or wider? Hope that makes sense.
#1188
Originally Posted by theisgroup
neither. you will need to use some washers on the mounting screws and the wide mounts.
Additionally, the BMI kit allows the use of any servo with the normal mounts. I had no trouble mounting the 9550 to my BMI chassis and I didn't have to "jimmy" it in.
#1189
Anybody know a good servo that uses the narrower servo mount?
#1190
Originally Posted by Fred Hubbard
-The '007 is better suited for carpet racing, and fixed what the T2 lacked in that department.
Keep in mind the '007 comes in 2 versions, rubber and foam tire. So your observation in only half true.
-Also, by just reading this last page, is something wrong with the bearings XRAY supplies?
Nothing wrong in terms of a manufacturing defect. XRay is saying that these bearings have tighter tolerances and so they need to be lubed sufficiently until they are broken in.
#1191
Originally Posted by Michael Barch
Thanks for clearing it up for me. I will get the US Spec version then. When I get this T2 007, I will be racing on-road for the summer, so should I get the Euro instead, and will it be a good carpet racer? Or vis versa? I can't afford both.
#1192
Originally Posted by STLNLST
Are you running foams or rubber tire's on carpet? If it's rubber tire then get the EU 007 and that will carry over to the asphalt. If you are running foams then you have a tough choice to make.
So Euro edition sounds like it would suit me better? Yes, we can run rubbers on the carpet track.
#1193
I used to run foams, but near the end, before I quit, I ran rubbers. Rubbers took some getting used to, and some good prep work with the lube. Me, being a college student, on a budget. Foams are expensive, and you need to get a new set pretty much each week. Rubbers however can last a little longer, and IMO, take more skill. So do you think I will be better off running rubbers on carpet, and then it will be cheap, and cost me nothing to switch right over to the asphalt.
#1195
Alright thanks. I think the Euro suits me the best right now. I'll try and pick up the foam version next winter, for indoor season. See what I can do.
#1196
Originally Posted by Joel Lagace
And lets not forget with the multiflex ability some of the stiffy settings overlap between the EU and US versions, so its is possible to run the EU with just the addition of a ball diff for foam.
Acquiring the US wide top deck/alum posts, and running the posts in the outer position will help a good bit as well.
#1197
my EUs job is rubber tire on indoor smooth asphalt. any suggestions. i've seen the setups but other ideas on its function are welcomed. that and i've also toyed w/idea of 4/5cell.
Ult
Ult
#1198
