Xray T2'007
#961
Originally Posted by svines1972
2 Questions before I start the build.
1. I understand the edge of the chassis needs to be sealed w/ CA. How do you do this without runoff onto the top or bottom of the chassis? Very carefully is not the answer I am looking for. Is there a method to it?
2. Just received the kit and noticed the bulkheads are already attached, but there are 3 screws missing on the rear bulkheads and 2 on the front. Is this something I will insert later on or were they left out by mistake.
Rather then letting the glue run on the chassis, many have had good luck with using a Q-Tip dabbed in glue to apply it to the chassis edges. Try to use genuine QTips with the cardboard sticks - the plastic ones react with the CA and release a toxic gas.
2. Take the bulkheads off - they are just there for show at this point. The remaining screws to mount them properly are in the parts-bags.
#963
Gravity RC
Jag88, I wont say that it is good to have the chassis drag, but we are going so fast into the courners now that its hard to get them not to drag when the bite is up. I think that a little drag can be ok but a ton for me is not ideal atall.
#964
In the past I've used the qtip method with good success. I first soak the qtip in CA glue then dab it on a paper towel so it's not dripping wet. Then use the qtip like a brush and with light strokes coat the edges of the chassis.
To be honest, with my last two carpet chassis's I've been lazy and done zero CA. I will use a fill or dremel to bevel the edge a bit just to knock the sharp edge off. With carpet the only real concern is cutting the rug with a sharp edge on the chassis. On asphalt it's more important to glue the chassis so it doesn't splinter on a bad wreck.
#965
Can anyone tell me if a Team Orion lipo 3300 will fit...
in the EU 007 or not? If not, I'll be selling all most of my stuff until the smoke clears with the battery/tc configs. I'm waiting for a lipo/tc design standard.
#966
THe US kit the thinker chassis and lowered bulkheads made it very hard to fit.
I have two 3200 packs that fit real nice in the Eu. Still trying to get the right conter weights. Seems everyone around here shuts down for thanksging on Monday...Slackers I tell ya...
-Shookie <><
#968
Hi Guys,
Can anyone let me know what they're using for track width spacers front and rear, running Parma tires? I've seen many setups posted on the XRay site, most/all are using Jaco tires and stated 3mm. This appears to be too wide for Parma's.
Thanks,
Ralph
Thanks,
Ralph
#969
Originally Posted by ralph m
Hi Guys,
Thanks,
Ralph
Thanks,
Ralph
#971
ORION 3200 LIPOs in t2'007???
Originally Posted by Mr. Shookie
With the EU kit yes.
-Shookie <><
-Shookie <><
Hey Shookie,
So you confirm that 3200 team orion carbon edition LIPOs fit in the new 007?
Thanks,
Cham
