Xray T2'007
#3721
Xraysteve I tried your way and when I puled the trigger the car went flying like a rocket After the ice pack melted my finger looks like it has a racing strip burned in it now wow that smarted and still does. Soooo next time I'll try it with the tires off and use a glove maybe. Thanks Man
PS ..... How many people does it take to do this diff test ????
#3722
get off the thread purple car guy. it only takes one xray driver but it takes three hot bodies drivers to set a diff
#3723
You ugly car xray drivers are rude!!!! The best way ta set your diff is first pick up your car, you will need coveralls> xrays are always dirty, if I had one I wouldn't clean it ether. Then turn any wheel and if it's all like crunchy and wobbly then it's an xray (not worth fixing) Next thing ta do is put it in a trash can and get the best car > Cyclone < You know you xray guys all want one
#3724
Anyone know a good place to get a diff rebuild kit? Or can anyone give me the part numbers to do a complete overhaul on the diffs.
#3725
64P Spurs
Hi there,
What brands of 64 pitch spurs fit the T2'007 besides the xray ones? What's the biggest 64P spur that can fit?
Thanks.
Thanks.
#3726
RW, PRS, and Robinson spurs fit the 007, although the Robinson (and the non-Pro Touring PRS and RW) spurs don't have the motor screw access holes. Basically, all of their spurs fit the 007, some are easier than others. I think that the largest that fit are 118 tooth. Maybe 120, if you're lucky, or you grind away a slot in the chassis.
#3728
Guys, I just got my new replacement Chassis 2.5mm Graphite - Rubber-Spec.
To sand the sides, can you guys recommend what number sandpaper
grit I should use. I have from 200 to 1200 Grit, It's been a while since
I did my 007 EU! Thanks guys!
#3729
Guest
Hello!!I just got a t2 and I have a few questions. I have a 13.5 motor and a 87 tooth 48pitch spur on the car, what pinion do you recomend using (how many teeth). My car doesnt have swaybars do I need to buy them or leave it as is. What gearing do you recomend if I switch to 64 pitch gears, Ill be running rubber tires on asphalt track. Last one how about springs what color front and rear? Sorry for asking to many questions I just want to get my car running in the right direction Thanks
#3730
#3731
R/C Tech Elite Member
If you are running a 13.5 and/or a 17.5... You want to get the smallest spur gear you can find!! Seriously! Because brushless motors are super torque, so you have to compistate with a large pinion gear. Unless you wanna buy a whole new range of pinions, Try going to the smallest spur gear to be able run the smallest range of pinions possible
#3732
Guest
Thanks alot A.Rhodes and my car has a multidiff, I guess I have to buy some sway bars.
#3733
Guest
#3734
Also, for example, I was running a 007 last year with a 112 spur gear.. The max pinion that my bulkhead would allow was a tight mesh 38tooth pinion. And I was still undergeared with my 13.5.
I had 2 options.. Either dremel my bulkhead some to allow for the motor to move out to put a bigger pinion on (I didnt want to do that) or buy a 104tooth spur gear from Nexus Racing. (At the time, Xray didnt have their line of smaller 64pitch gears, So the only one I could find was the RW 104 toother..)
I am talking 64 gears though, Im not sure whats the smallest 48 pitch out there. Usually touring guys run 64 pitch to allow for finer Rollout/FDR outcomes and we leave 48pitch to offroad stuff.
~Ben~
~Ben~
#3735
~Ben~
~Ben~
