Xray T2'007
Old 05-28-2007, 12:03 AM
  #2641
Big B's Avatar
try moving your rear spoiler back a little, that will put more downforce on the rear tires
Big B is offline
Old 05-28-2007, 09:32 PM
  #2642
SammyZ's Avatar
Trader Rating: 138 (100%+)
anything else? shock position? spring rate?
SammyZ is offline
Old 05-29-2007, 12:50 AM
  #2643
SammyZ's Avatar
Also I talked to nexus racing about the plastic diffs. They said some guys are running them in their '007's for stock and 19t. I run a tight carpet course with a ss13.5 motor and it would only cost me $50 to upgrade to the plastic diffs.
Anybody here running the plastic diffs?
SammyZ is offline
Old 05-29-2007, 06:16 AM
  #2644
teamgp's Avatar
Post your full setup (including all the extra stuff like tires, traction compound, track conditions, motor, body, etc.) on the Xray Forum On-line Setup Sheets so we can take a better look.
teamgp is offline
Old 05-29-2007, 06:30 AM
  #2645
t4m1y4niac's Avatar
i will racing on 3th june on stock 19T (Peak Dynasti 07) handout using my new T-Bond (T2'007 EU )...with foam tires on asphalt track that have technicals area and about 35m long straight...i need help with starting gearing ratio...thx guys
t4m1y4niac is offline
Old 05-29-2007, 08:14 AM
  #2646
Big B's Avatar
Like GP said without any info on the setup its hard to help you
Big B is offline
Old 05-29-2007, 09:23 AM
  #2647
SammyZ's Avatar
Im running a bone stock factory US edition setup. The tires are double pink/orange up front and double pink in the rear with paragon sauce. Mazda 626 body, brushless 13.5ss, tight high grip carpet track 50'x75'.
SammyZ is offline
Old 05-29-2007, 09:36 AM
  #2648
teamgp's Avatar
Where is it loose?
* off-power (using full brakes, motor drag braking, or neutral throttle?)
* on-power (low speed and/or high speed corners)
* mid corner during throttle transition
How much of the front tires are you saucing?
teamgp is offline
Old 05-29-2007, 10:17 AM
  #2649
ottoman's Avatar
Trader Rating: 13 (100%+)
While you can run the Mazda on foams its more of a rubber tire body
ottoman is offline
Old 05-29-2007, 07:36 PM
  #2650
Tire Chunker's Avatar
Trader Rating: 16 (100%+)
delete
Tire Chunker is offline
Old 05-30-2007, 03:18 AM
  #2651
RCRacing.com.au's Avatar
Body Change = less rear grip... what the???
Hey guys I need help please.
I am running a T2 006 and i was using an East Coast Bodies Tune body and changed to a Blitz Mazda 6 as i was told it gives you better traction.
Well i've gone from driving on rails to very loose in the rear when you back off into the corner.
I'm running a solid diff in the front but really need some rear traction.
This body has helped with weight reduction but how can I get more rear grip?
I don't run any sway bars either as our track is a little bumpy too.
Should i change set up or body?
RCRacing.com.au is offline
Old 05-30-2007, 09:44 AM
  #2652
John_S's Avatar
what is your dropp set at? i had this problem and decreased my rear droop and it helped as less weight was transfered to the front of the car under breaking
John_S is offline
Old 05-30-2007, 10:42 PM
  #2653
Drewdc90's Avatar
If your running the original springs in the front that could be the reason, try increasing your rear downstops and stiffen the front springs to blue. Last time i ran at Meakin Park i had to run voilet springs in the front.
Drew.
Drewdc90 is offline
Old 05-30-2007, 10:56 PM
  #2654
I am running white springs front and light gold colour on the rear.
Thanks guys i'll try your droop suggestions asap.
Drew what weight shock oil did you run at Meakin that seemed to work?
I was going to try Losi 25wt front and rear.
Any suggestions?
Old 05-31-2007, 01:31 AM
  #2655
Drewdc90's Avatar
I ran Xray 30wt front and back, with the T2 2006 i ran two holes open in the front and four holes open in the back. I don't change shock oil, i just use the external shock hole adjustment for damping. Try the downstops first, if that doesn't fix it stiffen the front end.
Drew.
Drewdc90 is offline
