Xray T2'007
#2521
Drove my 007 first time yesterday....after 2minutes i broke a bearing to the layshaft
#2522
I've also had a couple Xray bearings go south on me. Did you clean and re-oil them before you built the car? I think Xray posted on the site a while back that the bearings didn't get packaged with sufficient lube and recommended that you clean and re-oil them to make sure they last...
#2523
Gravity RC
Noob: I will find this out for us, i assume the same thing but dont know for sure.
ff01: yes this was a problem in a batch of kits, they did catch the problem and post a bulliten about it but obviously its not your fault. re oil the rest of the bearings in the car. and if you pm me i will make sure you get another bearing. Thanks paul
#2524
#2525
It may have been just the first batch of kits that had this issue. I have had my 007 since they came out so that was probably the problem I had. Knowing Xray they did fix the problem once they found out something was wrong.
#2526
after the bearing broke i re-oiled the rest of bearings.
i drived it an hour now without problem
//thanks Peter
//thanks Peter
#2527
I didnt know about that problem when I built my kit, but I always clean and oil the bearings before installing them, you never know how long they have been on the shelf. I am starting to think the powers that be are out to get me though, I did all the proper chassis prep, first run a big chunk of the chassis falls off. Ok I CA glue the exposed CF, temperary fix for the Race for Grace in 4 days, then my brand new VFS-1 Comp 2 takes a dump on me, maybe I wasnt meant to drive again
#2528
Gravity RC
I know that the bearing issue was taken care of but not before a batch of kits were already sent off. Xray would never continue to use those bearings in kits knowing that some would fail.
#2529
i have bought 2 original 007's one i oiled the bearings one i didnt. the one i did oil never had a bearing problem but the one i didnt i had 2 bearings go bad. pulled all bearings out and oiled them and havent had a problem since
#2530
#2531
yes
#2532
Do you guys know if the Orion 3200mah carbon li-po will fit in the T2 '007?
Right now I got the platnium 4800mah in it but I have to stand it up on the chassis because it doesn't fit under the top deck ( I refuse to mod the top deck), It looks absolutely retarded taped like this!
Nexus racing says you can fit the Carbon 3200 pack by notching a divot into the pack to clear the layshaft bulkhead. Is that safe? I am afraid to dremel the Li-po case!
#2534
