engine temperature any one??
hi i have just recently bought a .21 engine for my buggy (gs bo3) and using my temp guage it read a maximum temperature of 140 degrees centergrade or celcius give or take, is that a good running temperature?
also what is the average temperature range for a nitro .21 engine and/or whats the max temperature it could reach with it still being with in a safe temperature level without it being over heated.
and finally what temperature is over heated?
sorry for the newb questions but i need to know so i can make sure it dont overheat.
thankyou.
thankyou.
If you can get that guage to display in Fahrenheit, then I can help you. Anyone else in here speak metric? In fahrenheit, 220 to 240 is average operating tempurature, but some motors run just fine hot, in the 260-270 range. I keep reading magizine articles saying to tune by performance, not tempurature. If that's the way you do it, you risk cooking the motor...
Not really. An engine running lean will not have good performance. A properly tuned engine will be in between 210 to 290 F (99 to143 C) and optimally it will be around 250 F +/- 20 (120 +/- 6 C). It all depends on the engine, air temperature, track conditions, driving style, fuel, glow plug, etc. so you can see there are many variables to consider. Therefore if it preforms well, exhibits a smoke trail on acceleration and doesn't load up or bog down then you're in the right range.
AreCee
I came in here to answer his question but you said exactly what I was going to say.
Listen to AreCee as he is spot on!
yup.
ok thankyou very much for your replies it helps alot i just ran my races this weekend and it got to 143 degrees celcius or around the 270 farenheight so it seems to be running well i just cant go any richer now the tune is right, it was funny because my first race i ran real rich to cool it down and it ran out of fuel from being too rich so i guess this engine just needs to run a little hot for the best performance. thanks once again..
Registered User
As long as the engine runs strong
i am using an sh max torque 2 pc pipe and the conditions were about 22 degrees celcius wheather was sunny as it is spring here its getting hotter so its not too hot but warm on a quite small sort of a track with medium bumps nice traction bit dusty smoothish but bumpy track with a nice straight to only just get to max speed then a right hand turn so there you go should cover it.
thats what the engines up against i managed to lean it out with good response reaching 134 deg celcius still with fuel left in tank after 5 min heat.
oh and bschorr i tried that and the engine blew up can you pay for a new one? j/k
As long as the engine ran well with good smoke, I didn't worry about the temperature. Yes, I still checked my engines to make sure they were up to temp and etc before tuning, but other than that and the occasional temp, no.
I had the older GS B01 engine at one point. It ran really well at about 320-335, so thats where I ran it. The engine lasted plenty long that way.
cool killer that makes me a bit relieved hearing that due to you having the gs bo1 how did it idle? was it a loud idle or quite and soft? mine sounds like it wants to get up and go a little whilst idling but the car doesnt move then it retires into a slower softer sounding idle which will then stop after a little while of sitting there i dont mind it doing this so long as it has that time frame before the stalling, very painful when a car stalls on the start line 5 seconds before the start hehe......'ouch'.
All that is that you are experiencing is the engine loading up at idle. With any engine with a properly tuned low-end, the engine will load up on fuel and die after you let it idle for a little bit.
A good way to test the low-end is to first tune the top end needle to 1/4 turn richer than max power, then clear the engine out and bring it to an idle. Immediately pinch the fuel line at the carb and it the idle should get faster and die in about 4-5 seconds. Any longer and its a tad rich. Any shorter or if the idle doesnt increase in speed, its too lean...
hope this helps
