how to set up step charging?
just want to know...does anyone help me I use IB4200
1 st step ? mAh ?A
2 nd step ? mAh ?A
3 rd step ? mAh ?A
? temp ? mv
thanks everybody
1 st step ? mAh ?A
2 nd step ? mAh ?A
3 rd step ? mAh ?A
? temp ? mv
thanks everybody
Nexus Has profiles for just such a thing using the CTX Cell Master, Try out the Highlighted links about half way down.
http://nexusracing.net/newsdesk_info.php?newsdesk_id=19
thanks . and how about IB4200
Dont use step charging function for IB cell, IB recommended use 5-5.5A linear for 4200
Step 1 - 0-3000mah - 7A
Step 2 - 3000-3050mah - 7A
Step 3 - 3050-5000mah - 7A - 10 cuttoff - 50 degree temp cut
I use the above step on my cell master, which allows a very long lockout & less chance of a false peak. The above can be altered to 6A or 6.5A, 7A will give you the most punch out of the pack.
Originally Posted by A. Rhodes
You can try the following set up using step for IB4200:
I thought that the whole thing about step charging was changing the charge rate. You are not really step charging as you are charging at 7A for the whole charge.
for 4200:
up to 3000 with 7.0 Ampere
up to 3030 with 0.2 Ampere
up to 5000 with 4.5 Ampere
Flex off!!!
Temp 50
delta peak 06
Flex off!!!
Temp 50
delta peak 06
i'll try all of your set up,thank you
i try this last night
1. 3500 7A
2. 3550 0.2A
3. 5000 6A
flex off
5 mV cut off
50 degree C
ORION lipo version
BUT!!! the charger cut off about 4100 mAh. I charge the same cell with CDC V6.0 at 6 A ,cut off at 4400-4500 mAh.What wrong?
1. 3500 7A
2. 3550 0.2A
3. 5000 6A
flex off
5 mV cut off
50 degree C
ORION lipo version
I believe what happened is called cell saturation. The step process allows latent energy to be dispursed into the cells. The number is lower but the cells energy density may be greater. The way to test this is by discharging and see what numbers you get or by running the vehicle and see if it gives you more power.
I try step charge and rest the cell 5 min.after that discharge at 10A. rate for 8 min. The charger shows more volt and lower IR .I think ,this is the right way.but the cell need to charge more than its spec? or only for run my car at 8 min at the race day. The cell cut off at 3900-4100 mAh.
