Team Losi JRXS Type-R
https://www.tqrcracing.com/shop/prod....asp?p_id=5250
That is a 3-racing center pulley which is the correct pitch, tooth number, internal diameter, and it is set with a set-screw. Just ditch the non-spur side pulley, space the pulleys out, grind a flat spot in your drive shaft and you're good to go.
It should look something like this:
http://www.rctech.net/forum/attachme...y-img_3544.jpg
Big shout out to RCTech's masterhit for the method.
If you wanted to be able to run new spur gears, forget about it. All of the adapters are gone and with a stock 118 tooth spur you can gear to 3.85:1 anyway, plenty to race 17.5.
Thanks for the advice. I just came across an unopened kit and I am going to run it in 17.5 or 13.5. I have an old one but it has a lot of miles on it but it does have the FF spool and a spur adapter so I'll harvest them out of it. Just really liked the FF layshaft when I had one years ago.
Just throwing this out there on the discussion as well as in the wanted section....looking for the diff hub which is the outdrive on the left front or right rear for one of these cars. Please let me know if you might have one available. Thanks, Peter
PM sent.
They are extinct. BUT, if you were looking for one to fit a wider LiPo than is normal you can still use these:
Thinking of going VTA with mine. Anyone have a gearing setup for 25.5 motor? Thank you in advance.
Check your local rules to see if they require a 4:1 gearing, which is achieveable easily with the stock spur gears and normal pinions. If not, I have a spare adapter that will let you run a normal spur gear that I can send you. Just PM and don't make me send to to Nome Alaska or something.
I need a spur adapter for 2 of my losi JRXS type-R. Please some help!!! I can't find them any place. I am putting 21.5 motors in each of them. PM me if you can help me.
HELP HELP LOSA3318
Gents I present myself with hat in hand. Hoping to rescue my JRXS-Type R. It was discovered upon restoration that my diff hub is destroyed.
Not seeing any available on line, I hope someone will step up and help a brother out.
Name your price or anything I may have by way of parts to trade. I have a ton of NEW spares, just not one of these.
Best wishes,
Rocco
Best wishes,
Rocco
Thanks J Lee for send me out a couple Diff hubs.
Loss3344 and losa3335 are really needed in the Rc community...
From that list, only 3345 and 3346 are good for me.... I will take any of these two you still have left whenever I see you.... Thanks...
Pm sent.....
I still wish to find lots of losa3335 kits available....
