Team Losi JRXS Type-R
Company Representative
I measured with a ride height gauge then once in a while check with a Losi plastic gauge to make sure Left and right is equal, I found the losi guage very acurate.
You'll find here:
http://www.rctech.net/forum/electric...culator-5.html
Also if you use Win7 read the last page.
Our carpet is literally tacky from the Jack the Gripper sauce, so these low roll centers were just there to reduce the likelihood of traction rolling.
I have a way with droop which gives me great results when setting tweak. I use setup wheels for rideheight and adjust for different worn rubbers. With setup wheels on I use my droop blocks (19mm high) and measure the gap between the setup wheels and the bench (setup board). Add that number too the rideheight setting. Then subtract that number from 19 and you have the droop. With the setupwheels on I can do my droop, swaybar tweak, rideheight and tweak all in one pass.
Hey greg
i see you have a white bladder post it on your set up sheet. what brand is that? Tamiya? is it softer? I found a stock black one kida brittle in this weather, I was at the RC madness lastweek and a track Temp was 35F! shattered few parts in there skating.
The white bladders are LOSA5327, much softer than the black ones, which I didn't know were OE in the Type-R. Learn something new everyday! Dude, you broke a shock bladder? WTF!
no I didnt brake a bladder even thought a black bladder felt like a piece of graphite.
I broke many other parts, in30F temp, one shot one killed.
Has anybody tried the different bladders back to back? Is there much of a difference?
I recently tested different rebound settings from extreme to zero and found no difference in feel or lap speed. I imagine that different bladders would only effect rebound?
I wanted to try white one on the carpet ASAP
I also noticed a difference. When I correctly set rebound to about 4mm, I achieved even better side to side weight transfer, this is without the use of sway bars. On a bumpy surface it is you don't want to use too soft of an oil, then your car will bottom out, which you don't want.
Hey guy's i'm looking for an RCGT setup for a Type R. Is there a good base setup out there?
Jerry
Jerry
Well..... I'm back!
I was forced to stay awya form my Losi (and all related upgrade project) for job reason, but now the new season is approaching and I'll do my best to race as mcuh as possibile.
We will have a new class (for us...) using 13.5 motor (single brand, Lipotech).
I need all the ideas and suggestions from you 13.5 guys (I was 4.5 before...)
I gearing should be in the 4-5ish area. Will be worth use the 41 gears inestad of the 42 in the diff? Just to avoid pinions big as frying pans...
