Team Losi JRXS Type-R
#9526
Here's Dave Johnson's setup from the recent Fastcats race.
http://www.rctech.net/forum/attachme...pe-r-typer.jpg
#9527
Yes we are doing both diffs. I had a problem with my spool at the Carpet Nats and Larry told me to run the d-ring on both sides. I did my spool with a dremel and had no problems since. I also am doing my regular diffs now, but had them machined as I wanted them to be a little more accurate.
I could not get a 5200 40C SMC pack to fit in my car. The new 4700 pack should work, but you may have to grind down the humps on the bottom. I have not got my pack to try yet.
#9532
let me know if you want to see it, i can pm it to you
matt
#9533
If you are having a problem with the diffs slipping we have been cutting a piece out of the aluminum diff half and putting on a D ring. Mark the aluminum part that stick up with where you need to cut off for the D ring to fit pretty tightly. Make sure you take everything off so the ring rides flat or you will have a major problem. But it works fine and the plastic diff out drive will fit in just fine. We have been doing it for a little bit now seems to allow you to run the diff a little looser but still be tight.
Right now i had to reassemble w/ the one that was in the car and it feel slike there is a high spot somewhere, and i'm blaming the thrust bearing.
#9534
Speaking of diffs, had a huge fight with mine last night only to find that the molded hole in the center of the diff pulley is like 1/16th too big!! Also the brass cage in one of my diffs made a pretty cool metallic flake for paint . Any suggestions on what to use for a thrust bearing instead of that losi one?
http://www.mcmaster.com/#7806k53/=1psv4l
#9535
Here you go godzilla foot
#9537
#9539
And as for the PINK car in that photo... you should find a pic of Ron's car. He's never driven a pink car and probably never will.
#9540
Yeah i was looking for a shot of his car from the battle of the bowl but i couldn't find one haha.
