Team Losi JRXS Type-R
#9406
It great! My pervious car xxxs G+ also on my table, I just buy some new parts for it and plan to play is as my second car.
The other reason for me loving losi very much is non-stop parts supply!
#9408
Location: Colorado, USA, The land of the free and the home of the brave!
Allright, all these measurements are with a custom lipo tray that is flush with the chassis-
Height avaliable- 23.3mm (21.3mm at the bulkheads)
Width avaliable - 46.5mm at the pulleys (un-modified)
Length avaliable-aprox. 139 mm with un modified bulkhead and jr 9000s servo with no serrvo mount spacers.
The orion lipo (3200) is 46.1mm at widest point, 137.5 mm long, and 23mm tall including the cell "bumps".
Looks like you got some pulley widening to do!! its pretty easy, mikexray posted how to do it a few posts back.
#9409
I'd measure again but my calipers must be in my friends tool box 'cause i can't find mine.
Am i the only one that took these demensions? it would be nice to have another source besides just my measurements, 'cause you never know...
#9410
Steel lipo tray
That's weird, I have an unmodified lipo tray and it's only 45.7mm wide x 137.8mm long at the flat part on the inside not to mention the rounded edge. I still have battery rubbing issues with the Orion 3600 (w46.75xh23.10xL137.7) I have when it shifts onto a pulley and belt for the front. Depth was 26.52mm bolted in the car and measuring from the top deck down then subtracting the 2.8 mm for top deck thickness. So it looks like the minimum measurements are...
lower width 45.7 mm inside of tray.
Upper width 46.5 mm at the pulleys.
length 137.8 mm inside of tray.
height 21.3 mm at the bulkheads.
If the battery has the cells bumps at the bottom (IP,Orion) the tray does not need modified. I've tried a newer smc 5000 and it would need some work to fit.
#9415
i had my steel lipo tray milled so the packs fitt in...the dremel tool took too long...
#9418
i will be at the track april 5th....
nitro racing this weekend
#9420
Having the steel trays milled is so much cleaner looking if you have that option. I was going to go the dremel route as well and remembered I knew someone with a mill and he does great work.
