Team Losi JRXS Type-R
#8986
Hey guys I'm getting out of the hobby for now so I'm selling my R
http://www.rctech.net/forum/r-c-item...on-extras.html
#8988
Get a dremel with a cutting disk and cut some "lines" into one end of the spring. Make it easy and cut 1 line for a 10.5lbs, 2 lines for a 12.5lbs, 3 lines for a 15lbs etc... It would only take a second to cut and you would then be able to remove the tags and keep your setup to your self if you want.
#8989
Just getting back into the hobby after a long layoff..... When I was racing before (Moses was playing T-ball and dirt had just been invented) companies used a small dot of paint to color code spring rates much like Associated does today only they did not color the whole spring.
#8990
I was rebuilding the diff and noticed that no matter how tight I set the diff it still slips. I figured out that the suspect part is the plastic diff drive (LOSA3318). With all that aluminum it still acts like a plastic diff because of that one part. It can't stand up to the clamping force exerted by the screw.
Does anybody know of an aluminum replacement part ?
Thanks.
Thanks.
#8991
Trader Rating: 7 (89%+)
#8992
I was rebuilding the diff and noticed that no matter how tight I set the diff it still slips. I figured out that the suspect part is the plastic diff drive (LOSA3318). With all that aluminum it still acts like a plactic diff because of that one part. It can't stand up to the clamping force exerted by the screw.
Thanks.
Thanks.
#8993
Interesting, I was wondering about that. Why would they design the diff to slip a little when everyone else has 'd' rings on both halves ? I would think the mod foam guys would
hate that.
Thanks.
#8994
#8995
#8997
Hi ya, i've taken a couple of pics for you, (sorry about the quality)
Being different colour they are quite easy to see, even on the car.
I got them from someone i worked with ages ago.
All they are, are little markers that elecricians put on to cables to identify them. They are similar to these,
http://www.eland.co.uk/cableaccessor...e-markers.html
have a look around electrical wholesalers and the like.
http://www.beachyheadracing.co.uk/tw.../pictures.html
cheers tim
cheers tim
#8999
C Hubs
I have been running Xray touring cars for a while. Decided to try a Losi type R. Wow, the C hubs seem to be made of peanut brittle. Just brush the wall a little and presto, C Hub in 2 pieces now....
Anyone else notice this ?
