Team Losi JRXS Type-R >
Like Tree52Likes
Old 01-01-2008, 08:33 AM
  #6151
Matt Howard's Avatar
Originally Posted by RCGaryK
Really? That's kinda odd but if it works, what the hell, right?
actually most foam setups have level pins. Rubber tire setups sometimes have some antisquat in the rear but that's it. I haven't tried Dumas' setup but I've run Schreff's and it works really well.
Matt Howard is offline
Old 01-01-2008, 08:38 AM
  #6152
RCGaryK's Avatar
well Rubber is my point of reference so kinda makes sense. have to run foams out of necessity around here
RCGaryK is offline
Old 01-01-2008, 09:05 AM
  #6153
hamster778's Avatar
Default Steering rack Question
Hi guys, happy new year.
I have a question about the steering rack.
We have the extra inner hole to change the ackerman settings.
How will this affect the handling of the car, would it better or worse
Has anyone ever used this setting
Cheers
Tim
hamster778 is offline
Old 01-01-2008, 04:52 PM
  #6154
yyhayyim's Avatar
Trader Rating: 26 (100%+)
Any one know of a good east coast hobby shop that carries Losi Type R parts? I need some spares for a race this weekend...
thx
Yohan
yyhayyim is offline
Old 01-01-2008, 07:30 PM
  #6155
dgullickson's Avatar
Trader Rating: 45 (96%+)
Originally Posted by J@UNE
It happened to me too. I'm now using the Axiom trust... Never had to look at it since...
Just got more in as well along with our new Ceramic Balls which we combined into a Diff rebuild kit with the thrusts.
http://www.axiommotors.com/specials....031b533ec5b31c
dgullickson is offline
Old 01-01-2008, 07:34 PM
  #6156
RobS's Avatar
I replaced my front with a Losi molded thrust bearing when it went... However when I blew my rear bearing I didn't have any Losi ones left in the shop but had an Xray one from my previous car that fit... Haven't run into any issues after that...
RobS is offline
Old 01-02-2008, 07:49 AM
  #6157
RCGaryK's Avatar
Ok, one other setup-related question. On both Mike's and Schreff's setup they don't indicate whether they are running the JR link in the high or low position. Does this mean they ran in the stock low position or replaced the JR link with a traditional ball stud?
RCGaryK is offline
Old 01-02-2008, 08:11 AM
  #6158
schreff's Avatar
Both Mike and myself ran the standard link with ball stud in the caster block. I used a tall ballstud (LOSA9947) in the caster block. I'm not sure whether Mike used a tall or shockneck ballstud on his car.
schreff is offline
Old 01-02-2008, 09:51 AM
  #6159
yyhayyim's Avatar
Anyone have an extra Losi 118T spur they can sell me? I need one for a race this weekend....someone from the east coast, so I can save on shipping!!!
yyhayyim is offline
Old 01-02-2008, 09:58 AM
  #6160
yyhayyim's Avatar
On med traction asphalt: will a 41T pulley spool up front give me better steering over all...I'll be running on tight technical track 140X70...is it worth getting?
yyhayyim is offline
Old 01-02-2008, 10:22 AM
  #6161
RCGaryK's Avatar
Thanks man. Can I assume you did this to get more steering over the JR link?
BTW, great reference to Grandma's Boy in your signature
RCGaryK is offline
Old 01-02-2008, 11:16 AM
  #6162
schreff's Avatar
I wouldn't say the standard link gives a lot more steering. If anything, the car reacts a lot faster to wheel movement. With how fast we're going on foams now at big races, a car that doesn't react = B main or worse.
schreff is offline
Old 01-02-2008, 11:30 AM
  #6163
JCB
JCB's Avatar
Schreff,
The car is working great, thanks again for you help!
see you at the track...
JCB is offline
Old 01-03-2008, 11:30 AM
  #6164
yyhayyim's Avatar
Default Spool Question
I wanted to use a 42T spool up front for this weekends race, but mistakenly ordered a 41T spool pulley...So i need to inprovise and need your advice. The pads that come with the 41T spool, are they attached/glued to the 41T pulley or are they detached? If they are detached, can I take the spool pads from the 41T pulley and put them on a 42T front diff pulley, and make a 42T front spool?
yyhayyim is offline
Old 01-03-2008, 12:17 PM
  #6165
TheCoolCanFanMan's Avatar
You can, but they are rather brittle, so be very careful if you wana go down that route, or choose the option of making sand paper rings, this works very well, but why do you wana use a 42 instead of 41, as the 41 gives you more traction on steering with a spool
Malc
TheCoolCanFanMan is offline
