Team Losi JRXS Type-R
#4606
Yep send them in, either post them here or sent them to
[email protected] <[email protected]>
Cheers
Tim
#4607
My buddy made an editable sheet and has one for everyone to down load on his site. www.gearchart.com Thanks anyways.....and why would you have an editable set up sheet? Does PW know this....LOL
Cheers for that.
Yep, there is one on the website ready to be downloaded
Cheers
Tim
Cheers
Tim
#4608
Super Moderator
#4609
Car Tweaked
just started Running the CF routed battery tray with the stock battery foam strips and with my EP4200s the tray will not sit flush to the bottom of the chasis and has thrown out the handling.
Does anyone else have this issue? Im tempted to trim the foam down so that the tray sits flush but wanted to know if there was other solution.
#4610
Super Moderator
Car Tweaked
#4611
Check to be sure the cells sit all the way into the tray, it may need to be touched up a little if the pack is not built tight and stright, or if there is an extra layer of shrink.
#4612
STLNLST's car was looking good at the Speedworld cup last week.
This car seems to be coming on.
Luck guys!
Luck guys!
#4613
Car Tweaked
#4614
#4617
C u there...........
Corona on Sunday? Im a bad influence I know
#4619
Setup Website
Hi Guys
Just to let you kow, i have updated the setup pages that i have been working on
check it out here
http://team-spoon.bravehost.com/
Cheers
Tim
check it out here
Cheers
Tim
#4620
Just read a setup sheet. It said Pivot is 0 deg. What is Pivot and how to adjust? Also, it said roll center is high. How to make it high? thanks
