Team Losi JRXS Type-R
#361
by the way it looks insane top job guys
#362
Originally Posted by chicky03
There is an asphalt setup. All you have to do is change the springs and change to a spool like Jay said. The car will just come ready for carpet as opposed to asphalt.
Paul
Paul
#365
It may just be me but the shocks look like cinventional size ones as opposed to the origional JRX-S size. They also look like they are press on fitment a'la Tamiya style. Is that correct someone? Looks like an awesome car so good luck with it guys! Have fun at Vegas, wish i could go race there!
#366
Here is the info listed on the Horizon site:
Main Page
EA3 suspension components provide strength and durability
Revised suspension geometry for improved handling
Revised drivetrain layout with centrally located, rear-mounted motor
New belt materials and drive pulley geometry
New "narrow diff" setup
Machined aluminum bulkheads and chassis braces
Balanced weight layout for improved handling and response
Ultra-narrow chassis and top deck
New ball bearing steering system
New front upper arm design for strength and stability
F/R diff setup ideal for carpet racing
Race proven adjustable bladder shocks with single or double O-ring configuration
Bottom-load battery configuration accepts NiMH or Li-Po packs
Picture/CAD captions:
The new front upper arm design improves strength and increases stability during hard cornering.
The Type-R design centers weight and mass for razor-sharp response and handling.
Battery packs load from the bottom, lowering CG and making quick battery changes possible
LiPo battery packs can be utilized in the Type-R bu using the included LiPo battery tray/mount set.
The "long arm" suspension configuration allows racers to choose a "short" or "long" suspension arm setting based on track conditions.
The Type-R's super low profile keeps weight low and centered for precise handling
Unique "reverse" CVD's (RCD's) are used on the rear of the Type-R to reduce wear and deliver a silky-smooth drivetrain.
The Type-R features innovative front and rear ball diffs. This setup is the "ticket" for foam-tire carpet racing.
The modular design makes maintenance of the Type-R easier than typical touring designs.
Machined aluminum bulkeads and chassis braces provide an ultra-rigid platform that resists tweaking and provides easy access for maintenance.
The centered and rear mounted motor configuration improve traction and handling while increasing cornering speeds, making the Type-R easier to drive "on the edge".
The new ball bearing-equipped steering sytem utilizes smaller bearings for reduced weight, and delivers adjustable Ackerman with quick-response geometry for improved steering reaction and feel.
Main Page
#368
The shocks as far as I know are the same except for the way they mount. They use the same springs.
Thanks,
Paul
Thanks,
Paul
#370
UBER!
#374
Originally Posted by ApexSpeed
Thanks!
I am pretty sure that that will be the price BUT this car looks GREAT!. I love the servo saver! I can't wait to see a pic of the real car. I am sort of dissappointed in the price but at least with Losi you get innovation at that price...not a $450 copy of what is already out there. Well done Losi
Now what do I need to sell to buy this car....hmm my never used dusty TC4...and/or my trusty JRXS
#375
Originally Posted by Tornado_Racing
Do the shocks, springs, pistons, etc transfer from the old car to the new car?
Yes
