Team Losi JRXS Type-R
#3616
Originally Posted by rocketron
What you have described are the OLD sandpaper disks that were used on the xxx-s. The PADs for the JRXS and Type-R are made of something like plastic and snap into the pulley one on each side. Not sure if the sandpaper will work well but before you CA everything try to get some of the new PADs
#3617
Originally Posted by syndr0me
I got a bit of a tweak in the car tonight. It normally runs VERY even from side to side, but I struggled with it this evening. Aside from the normal stuff (rebuild shocks, make sure chassis is flat, re-seat topdeck) is there anything else I should check, or any particular trick to straightening the car out? It seems like every car has an order in which to do things, or tweak tricks that aren't always apparent.
It was mentioned to me that making the shocks a little longer overall will allow for more suspension travel, and should let me run my foams down to the rim once again. I'll look into that when rebuilding the shocks in hopes of getting the tweak out. I was having trouble getting enough uptravel once the tires got around 54mm.
Also, for the second time, I had a front shock retainer pop off during a minor impact. I still can't figure out what's causing them to launch like that, but I've heard at least one other person mention the same thing. They seem to be snug on the shocks, so maybe there's something else I should be looking for.
Lengthening the shocks will definitely give you some more room on ride height droop with small wheels.
#3618
Originally Posted by Marcos.J
im not sure if anybody has done this , im too lazy to go back on pages to look, but this may help keep the front arms from breaking
#3620
How about this 'R'???
#3621
Marcos J. : from what bumper is that?
#3622
Originally Posted by Hebiki
great new addition with Jason Ertrachter signing onto Team Losi.
#3624
Its not the front impact that is the problem. It is a very light grazing with the side of the car that is snapping them. I don't feel like it is the axle. I have been running the graphite short arms front and rear and it has been real good so far.
Later,
Later,
#3625
#3627
i saw his signature. it says "Team Losi" also made a new avatar for him
#3628
Super Moderator
Later,
Later,
#3629
i see this bumper is the same width of the car ,plue i shaved the axles too so will see
Later,
