Team Losi JRXS Type-R
#3571
Originally Posted by DeLaSoul
Yeah Malc, 2 out of three "Rubber Ducky Racing" made the trophies this weekend, where were you!!
Malc TRDM (Mother Ducker)
#3572
Originally Posted by Paul1786511
Just to clafify it was 7th i can from to finish 2nd overall but it wasnt easy. I had a 6th, 4th and then a 1st in the last leg
Just to echo wat the TCCFN has said, the car was great all weekend, the slightest changes and you notice a big difference in the way the car reacts. which is great.
Big setup changes to be made for my next race, small tight track to basically the biggest track in england
GO ON THE LOSI !!!!!!!
Malc dont forget TEAM RUBBER DUCKY RACING!!!!!
Well done again Team Mate.
I will get some stickers made up I think, Dave you can design them ,and I will get them made up if you like?
Rubber Duck Racing
Malc
#3573
Originally Posted by TheCoolCanFanMan
Ed, how do you write one of those set-up sheets like you do? is there an active one you can fill out (im no pc guru so may be using the wrong terminology )
If you want, send us your setup details (same with you Paul), and I'll get them put onto sheets and posted here.
Ed
#3574
Originally Posted by TryHard
I just took a screen shot image of the balnk Pdf, and saved it as a Jpeg. Then used Painshop Pro to write stuff on it.
Ed
Ed
Malc
#3575
Do you guys have a part number for the tamiya red foam that you use in the shocks.
Is it the same as the one xray use as their foam insert.
Congrates guys on the good runs with the R.
Tim
Tim
#3576
Front Oneway
Can you use this http://www.losipartshouse.com/catalog/LOSA3350-250.jpg with the type R or do they have there own thats coming out in a couple of weeks
Where can I find Front Oneway for the type R ....for rubber tires on carpet
We are all still waiting on that one, should maybe be another TWO WEEKS
#3577
Tim
Tim
#3580
Malc
#3581
i would think it would work with the older short drive shafts and the new long wish bones. can't see why not.
will take a look later
Tim
Tim
#3582
ah, good piont that malc
#3583
Hey fellas!!
Just figured I would drop in and see what's up. Larry and I have been running asphalt for the past couple weeks too and the Type R has definitely treated us well. We're still working on setups as it seems Larry and I really can't run the same setup. I guess that only works on carpet for us.
Out of the 2 weeks we've run so far, I TQed both weeks with Larry winning week 1 and me winning week 2. We run at Jackson R/C, which is a beautiful facility in Jackson, NJ. We also get to race with Mr. Jeff Cuffs, which is awesome. We have great races all the time. The track is basically medium bite and pretty open. You can see pics of it here.
Anyhow, for the 2 weeks we've run, we picked up over 3 tenths in lap times between week 1 and week 2. That change in speed is mainly from Larry and me working on setups and just finding more speed. We are NO WHERE near done yet.
Here's my setup for other Type R owners to check out. This has only been used at Jackson so far so I don't know if it's something that will translate to other tracks. By all means, if you want to try it, go for it.
PS: The setup sheet was done using Photoshop. This was NOT an editable PDF.
#3584
Originally Posted by DOTMAN
I thought I read earlier in this thread that some people were using the older one-way but with the older axles and short arms
#3585
Malc
