Team Losi JRXS Type-R
#2701
Originally Posted by RussB
don't use the losi horn for ko servo's. i've always had them jump teeth on me.
i use the ko or airtronics plastic horns with the metal ring around the splined part, they work great.
#2702
Originally Posted by BHenderson
No Brant it is you who is "special" not your KO Servo lol. What's up Yeti long time no talk, couldnt miss a golden opportunity to bust on ol Brant
#2703
The car definitely turned a lot more using the kit setup without gluing the sidewalls. So, thanks for cluing me up to proper tire care. The car is awesome. I need to make it turn a little more to suit my (lack of) style, but I bested my previous fast lap by 2 tenths several times throughout the night.
The lower bumper plate seems a little bit fragile. I'm pulled the screws out of it during a single front impact. Is there a trick to making them last other than not hitting anything? I only hit two boards all night, and one of them killed it. :-)
#2704
Are you using the kit bumper or something else? I have not had an issue with that after I switched to PDub bumpers and trust me, I have hit a few things with those bumpers!!
#2705
#2706
#2707
Stalker!!!!!!!
Go play in the XRay thread!!! Leave the fast guys alone!!!
Brant
#2708
Malc
#2709
I used to use an AE horn..
the new horn 23- fits the KO as mentioned.. and does not skip.
Just an FYI for you guys.. dont run the solid bellcrank. I ran it for 2 rounds of practice at the nats because we couldnt find a spring for the saver.. and those two rounds resulted in 2 broken servos.
Found a spring (thanks Kevin) and have not broken one yet.
KB
KB
#2710
Paul
#2712
Originally Posted by rocketron
hey coolcan are you having this probelm with the new horn from the type-r? with an airtronics servo?
Malc
#2713
Originally Posted by TheCoolCanFanMan
I only wish I had a Losi Type R, there still not in the UK as yet I run a KO 2173 and do not run the nomal horn as I find they strip to easy. so I use the one with the metal ring that sits around the spline section.
Malc
Malc
#2714
KB
KB
syndr0me - with almost 2 years on my jrx-s, which i believe has the same bumper, and many many impacts i've never even come close to breaking the bumper plate. i run a p-dub bumper. you do have the mini locknut in the middle hole, right? if that's missing i could see it coming off very easily.
#2715
KB
KB
Malc
