What lubricants shall I buy? >
Old 08-13-2006, 04:31 PM
  #31
Oasis's Avatar
Trader Rating: 38 (100%+)
He's talking about WD-40, Only use it on Rubber Tires...Not my choice on traction compounds but it does work in a pinch.
Oasis is offline
Old 08-13-2006, 05:12 PM
  #32
MK_Arbiter's Avatar
I think he's talking about both.
Originally Posted by nf_ekt
A little bit of synthetic motor oil rubbed on the tires, let sit for an hour or so, even longer if you want.
I have a set I did this to about a month ago and never used, the tires feel very sticky and good to run
a non related question, but what are comm drops for?
MK_Arbiter is offline
Old 08-13-2006, 06:42 PM
  #33
ASM
ASM's Avatar
Trader Rating: 30 (100%+)
Originally Posted by vtl1180ny
You're a good consumer Huh? I bet you believe the enzyte commercials too....
The DIP traction compound does work very well especially in low traction situations. Being that it comes from Schumacher, there's a lot of it being used around here. However, it's $12 a bottle or so...
ASM is offline
Old 08-13-2006, 08:27 PM
  #34
Oasis's Avatar
I would not use oil on my tires...Rubber or foam, At $40 + a set I'm not taking any chances. I will use what I know works. Com Drops are used to lube the brushes to help break them in, I know some guys use them for a performance edge (I don't think it works) From what I have seen it softens up your brushes and gums up the com. When used every run.
Oasis is offline
Old 08-13-2006, 08:59 PM
  #35
MK_Arbiter's Avatar
So is it a good thing or a bad thing? And while on motors, is motor spray specially formulated to not damage the motor or will break cleaner work?
Old 08-13-2006, 09:34 PM
  #36
nf_ekt's Avatar
Trader Rating: 115 (100%+)
I tried alittle synthetic oil on rubber tires, it took awhile to settle in but the tires were really sticky as a result. It softened the rubber up a bit. Results were pretty good though the DIP stuff had a slight edge. Try it on a used up tire that your about to throw out soon, just put on a thin coat and give it about 30 minutes or more. It will make the tires sticky. Simple green followed by WD-40 works for one guy I know I tried it and the results were decent. These were not tried on foam I think paragon is usually a safe bet there.
nf_ekt is offline
Old 08-13-2006, 09:49 PM
  #37
Oasis's Avatar
On the com drops most racers I know don't really use them. I have used them to break a motor in and can honestly say I could not tell a difference in the performance of a motor using or not using com drops (*notice I did say I*, I'll save the $6 and not use them. The one thing I look for in a motor cleaner is residue...As in I don't want any left on the com. Some Break cleaners use solvents and some don't. Most of the hobby shops in my area sell motor cleaner for $5 to $6. nf_ekt I do know that some guys use sun tan LOTION (not OIL) on foam tires with good results on asphalt. Back in the "day" this is what most guys running pan cars used (it was hard to find traction compounds) I have used WD-40 and I know it works but their are some better products out their.
Oasis is offline
Old 08-13-2006, 10:19 PM
  #38
MK_Arbiter's Avatar
My local hobby shop sells motor cleaner but it's quite pricey at 10 bucks a can, so brake cleaner is my cheaper option. Do all brake cleaners leave a residue? Is magnum force motor spray any good?
Old 08-13-2006, 10:26 PM
  #39
nf_ekt's Avatar
suntan lotion is a go for foam tires I like it on asphalt for 12th scale. Try the synthetic on a rubber tire it will soften them up, but yeah dip seams to work alittle faster/better.
nf_ekt is offline
Old 08-14-2006, 12:58 AM
  #40
GTRtuned's Avatar
Default Good lubes
Niftech works really well on bearings, motors, and diffs...
GTRtuned is offline
Old 08-14-2006, 04:35 AM
  #41
VooDooPH's Avatar
Trader Rating: 18 (100%+)
just wanted to add... i use a fast dry contact cleaner to clean the motor. so far so good.
VooDooPH is offline
Old 08-14-2006, 10:06 AM
  #42
MK_Arbiter's Avatar
What brand is it? You can use any spray as long as it doesn't leave residue right?
Old 08-14-2006, 11:53 AM
  #43
teammediocre's Avatar
You have 232 post and your asking questions like this?Seriously what the hell have you been doing on here?Search and read around it's not that hard.
teammediocre is offline
Old 08-14-2006, 08:30 PM
  #44
VooDooPH's Avatar
McKinetic... dunno if its available where you are. but i've found that its slightly more expensive than the usual r/c motor spray so i might switch when i finish the can i have.
VooDooPH is offline
Old 08-14-2006, 08:49 PM
  #45
nf_ekt's Avatar
Off-topic, but NICE F#*KING AVATAR. Clutch rules big-time. Still got a tour shirt from '93. Good stuff.
nf_ekt is offline
