Team Orion 3200mAh Race Spec LiPo >
Old 03-16-2007, 11:33 AM
  #946
MrBlack's Avatar
Originally Posted by or8ital
So in the experts opinions am I ok to charge at 2c (6.4A)?
Yes. Kokam says the cells can handle it and therefore I stand by what they say.
I have charged my 3200's many times at 6A and my 4800's at 9A
MrBlack is offline
Old 03-16-2007, 11:34 AM
  #947
[QUOTE=MrBlack]MRC was supposed to send us a charger to test once this happens and it tests out to work properly then we would recommend it, however until this occurs we cannot recommend using it.
QUOTE]
MrBlack, FYI -I tempted fate and purchased a 3200 Carbon and charged it with my MRC 989 charger. I have charged it twice and in both cases the charger stopped charging after the battery reached 8.4 volts. Thus far the MRC 989 appears to be charging it okay. I guess time will tell. My risk I know.
Squating Goat is offline
Old 03-16-2007, 01:21 PM
  #948
MrBlack's Avatar
[QUOTE=Squating Goat]
QUOTE]
I hope you have better luck then we did and I am sure there are those out there that have and will continue to.
MrBlack is offline
Old 03-16-2007, 02:06 PM
  #949
minicooper's Avatar
Originally Posted by Disaster
Here is a link to the CellPro. It is a great charger up to about 3000-3500mAh batteries. If you charge a 4400mAh battery with it, it will take about an hour and a half to charge vs. 1 hour, 4 minutes, for the 3200mAh battery. It won't hurt the charger according to FMA Direct...just take longer.
The Cellpro automatically balances as it charges so you don't need a separate balancer. You will need to buy or make an adapter, depending on what brand of Lipo you have.
http://www.fmadirect.com/products.htm?cat=45&nid=4
I bought this charger (cellpro 4S) for my helicopter packs but used it this past weekend on the Orion 3200 pack. I only have one lipo pack and was able to get it charged for all my heats using the 3 amp max. I used anywhere between 30 and 50 percent of the charge (according to the chargers display). Sorry I did not time to see how long it took to charge the pack.
Everyone else around me was using the Orion charger with no complaints.
FMA Direct has another charger that will charge up to 10 amps
I sent you a PM with the link.
minicooper is offline
Old 03-16-2007, 02:11 PM
  #950
Trader Rating: 38 (100%+)
So we finally determine we can do 2C and then I find out my Duratrax ICE cant do 2C. I assume setting it to 6400mah and the charge % to 50% isnt the same b/c of the CC-CV charging. Are there chargers that do 2C?
or8ital is offline
Old 03-16-2007, 02:23 PM
  #951
linger's Avatar
The ICE will do 2C. Just set it to 6400 mAh and it will do the CC/CV correctly. The only thing you will loose is some of the safety logic. The ICE will not charge beyond the capacity you input in. So, if you enter 3200, the ICE will stop charging at 3200 even if the CC/CV is not finished yet.
linger is offline
  #952
MrBlack's Avatar
http://www.teamorion.com/Products/Ch...+_+Dischargers
It will charge up to a 5000mAh LiPo at 2C
MrBlack is offline
Old 03-16-2007, 03:16 PM
  #953
Thanks! That worked. Looks like it will take about 20min to fully charge the 3200.
or8ital is offline
Old 03-16-2007, 04:43 PM
  #954
414MPH's Avatar
I have just gotten the graph this morning from Kokam, here is a chart showing the 3.2A (3200) cells being tested at 2C charge rates:
Discharged at 45 amps? Try that with a NimH and see the smoke and lower voltage.
Has any-one done a discharge curve for the 4800 or 3200 at 30 or 35 amps? Post curve if possible please.
Marty
414MPH is offline
Old 03-18-2007, 09:54 AM
  #955
c1 racin's Avatar
MrBlack, (anyone) will the Team Orion Avionics Advanced Flight Charger do a 2C charge? If so, what are the setting to achive the 2C charging?
c1 racin is offline
Old 03-18-2007, 12:22 PM
  #956
MrBlack's Avatar
No it will charge at 2C It is designed as a (idoit proof) charger, thought we know nothing is truly idiot proof it is designed to charge automatically at 1C based on the capacity of the cell entered, it also desides S rating based on voltage so the user only needs to worry about his batteries Nominal voltage and capacity, two things that are primarily labeled on the cells.
MOst other LiPo's besides ours cannot handle more then 1C and since many will use this charger for other brands of Lipo's we felt the need to keep it simple.
The Team Orion Advanced Charging System Charger (the bigger graphite looking one) will charge LiPo at 2C up to 5000mAh.
Later this year we will have another solution for charging but I cannot disclose anything at this point.
MrBlack is offline
Old 03-18-2007, 01:33 PM
  #957
RCGaryK's Avatar
What does it do for the capacity vs voltage output versus charging at 3.2A?
RCGaryK is offline
Old 03-18-2007, 04:45 PM
  #958
linger's Avatar
pretty much nothing. No performance gain from higher amperage charging
linger is offline
Old 03-18-2007, 05:42 PM
  #959
MrBlack's Avatar
I second that Ling is correct.
Another benefit of lipo or if you like the voodoo a dissadvantage.
MrBlack is offline
Old 03-18-2007, 06:21 PM
  #960
RCGaryK's Avatar
Soooo...OK this is blowing my mind here...
You can charge at a higher rate...
To charge faster...
And not hurt Capacity?
RCGaryK is offline
