glow plug
I run the vantage pipe with a p5 I have the top end pipe, my motor is has very low comp 6gal on it but that pipe made the top end just screem I had a mid RB before. One good thing is there is no heat transfer to the gas tank and you can put your finger over the exhaust to shut it down. All the heat goes out the pipe rather than in the car.
Bad thing is you need to keep it up a 1/8" from the side gard or sand and dirt will make a hole in it over time(I just fixed mine with 5 coats of ca glue before it made a hole).
guys i would still like to know what kind of plug you all are running in the p5x. because i have some lc3 left over from my revo days and wondering if i can use these in this engine, thanks for any info.
I run a Mc8 or 9 depending on the track. Longer straights and i run the 9.
