New Novak Stock Brushless
#376
I just seperated my pod from the main chassis on my CK and the motor was definitely the culprit.... Once I had it off you could see how much it was pushing against the pivot...
Advice to guys running link cars.... Get the smallest spur you can, the motor can is larger than a standard 540 brushed. Bevel the pivot linkage and keep the motor off of it....
I like to run my tires till I can't make ride height anymore....
#377
Originally Posted by vtl1180ny
Ran it in my 12th scale today and wow.... I couldn't gear it up enough, actually screwed up my pod plate on my CK because the motor was up against the pivot. Wish my LHS had the 88 tooth gear... Oh well.... I ended the day at 96/34 gearing and it was coming off the track with the motor slightly warm and the ESC ice cold (no fan btw...)
How can you tell new endbell (sintered rotor capable) vs old endbell???
#380
Originally Posted by James35
This motor has a lot of torque. You'll end up gearing much higher than brushed. I went up 10 teeth.
He isn't kidding.... This motor is all torque.... Everyone kept saying my car looked better every lap....
#383
So we're pretty much saying a 50-60mm rollout here???? Possibly even higher....
#386
Originally Posted by heavy
I presume you are talking 1/12th scale here - certainly not touring cars
Yes we are talking 12th scale....
James, with 78/40 gearing and 50mm tires your pretty much running an 80mm rollout!!!
#387
Originally Posted by SRC_DRIVER
Are you guys running the same overall gearing with the 13.5 as with a regular stock motor or does the roll-out change with this motor. Im interested. Could someone post the gearing compaired to a stock motor?
Thanks,
Thanks,
I posted my first test results (post #338) same gearing throughout the whole day, and came in with very similar lap times brushed/brushless. I havnt had a chance to gear it up like some of the others have.
Pete
#388
Trader Rating: 102 (100%+)
same here
double post...
#389
same here
Same thing here, keeping my gearing about the same as when running with a brushed motor.
+1 or -1 a tooth depending on track size.
I don't run oval so gearing it to the moon won't do much good...plus if you gear it high just because the motor can take it chances are you won't be allowed to run with the brushed racers.
If you want to go faster than stock..try a 4300 or 5800...or just a brushed 19t. unless you're bashing or your track accepts you gearing to the moon.
#390
Geared it up 5 teeth (comp to brushed) to about 37mm rollout (27p/84s, xray). it was really quick. motor got slightly warm, but not too hot to touch and with no heatsink on the motor, and no fan on the GTB.
Pete
Pete
