hot bodies lightning2 pro / KHZ parts
Nope, I ran without c-clips. The only down side is the little screws that retain the hinge pins have phillips heads on them and strip easily especially if you thread lock them in (which is a good idea). So If you have some extra hex head hardware in your tool box use that instead of the phillips stuff. Will save you some headaches down the road.
