Losi Truggy
#1351
I got next results:
LOSA1755 - Adjustable Rear Hinge Pin Brace W/Inserts: 8B/8T
#1352
My Setup Station is quite precision, but goniometer does not precision. Now I completely disassembled rear of my 8ight-t and have done measurement of all angles with use of digital caliper and trigonometry.
I got next results:
I got next results:
#1353
Man, now I am going to have to tell everyone I run 2.7 x 3.25
#1354
speaking of Losi
Hey guys I have a Losi Eight T Pro truggy roller for sale $200 extra parts ($50 worth) and extra set of rims and tires. [email protected]
#1355
run time....pics.... ? detailed list of parts ? its the least u could do.
#1356
I got next results:
I got next results:
#1357
sterring
i boiught a 8t a mounth ago the pro kit. new but old to this raced eltric 9 years ago and got out. anyways the steering is bining up both ways when u turn the wheels. anyone have this problem. it was smooth then after a couple runs it stared binding up. what is the servo saver supose to be tightened to on these?
#1358
o and also the screws that bolt to the steering servo on the top plat are striped anyone know how i may get them out hate to buy the whole new servo saver and top plate
#1360
post some pics
that'll bring more attention
GH Racing by Golden Horizons: www.ghhobby.com
High Quality Machined Aluminum Parts and Accessories with LifeTime warranty
E-mail us at: [email protected]
#1361
Your servo saver adjuster nut may have backed out. It might be riding on the chassis now which won't let the steering posts turn. Remove the steering assembly, apply a small amount of loctite to the threads of the post, move the nut up a short ways, wipe off the excess loctite, and re-assemble. That should fix you up.
#1363
About toe-in I'm fully confident, I measured it twice and got the same results. You can take stock rear brace and adjustable rear brace with 0.5 insert in and you will get perfect alignment between holes for hinge pins. Anti-squat is not so precision, it's depends from accuracy of plastic bulkhead. I got different measurements for left and right sides. So it's average numbers. For stock rear braces I got next results: toe-in 1.97 degree and anti-squat 3.15 degree.
Also, adjustable rear braces lift up hinge pins about 1mm relative to stock rear braces.
#1364
i have the losi 8t and i want to use the losi starter box but it isn't working. o put the quick change motor mount and the back plate what else do i need to do and i dint want to grind down the chassis
