Losi Truggy
#198
Just got mine.....
It looks great!!! I will post some pics after the painting.
#199
[QUOTE=glassdoctor]Thought you guys might like to see the stock tires next to some others... these are Switches... makes the Losi tires look pretty tall.
QUOTE]
They are taller but less side wall.they dont seem to roll over like the others.the track we run on they hook up nice.
QUOTE]
#200
After taking my “Roller” out of the box I have to say I was very disappointed.
The front shocks where half empty, the rear one’s had air in them, center diff was leaking and none of the tires where properly glued.
How can Losi say it is “Professionally built”?!?!?!?!?!?
#201
maybe they had been drinking when they were putting yours together ??
#202
you don't want to get the ones that where built right before lunch...right after lunch...and just before going home time. the rest of 'em should be good to go.
you must have gotten one of the right after lunch rollers.
#203
yeah or its the last one for the week, your car was made on a Friday afternoon!! what a beacth
#206
It's a JP mods P5 .21 and a Jammin P-1 pipe
oops I guess the pipe's not there in that pic huh?
#207
Mine came built properly with locktight in all the right places. The only thing wrong was the adjustment nut on the servo saver was set too low and it rubbed on the chassis therefore binding the steering.
On my track the car is almost set up right out of the box. It lacked rear on power traction but I made the rear camber link longer, put grease in the rear diff and it improved.
On my STR I run Cody Kings setup which called for 18,000/22,000/2000 f/c/r
the truck is very dailed. I am thinking that since the str and the 8T are almost the same size and weight, those diff oils should work. What do you guys think?
Rick thanks for the link but for some reason I cant access it. If someone has it please post it on here.
#208
#209
And a couple pics I took tonight...
#210
ha ha NO YOU CAN"T!!! hee hee
here's a couple more pics since you like it... it's growing on me a little but I wasn't crazy about it at first... looked like I cut two bodies and joined them franken-style.
