Team Orion CRF Wasp Rev X-Dyno results
#1261
Location: West Ozzie living in Merrigum...Shepparton...Victoria
Trader Rating: 13 (100%+)
NANO~ Is there and new CRF .12 models coming in the next 3 months. Got the Australian Nationals in October so getting thing organised. If nothing I'll go ahead and get the Discovery Set. Currently running the Cyrul combo with good results so sticking with the CRF's and wouldn't mind running/trying the new pipe.
Cheers
Cheers
#1262
Cheers
Cheers
From Team Orion we currently have the Discovery set (06 updated engine, pipe, crf clutch parts and big carb insert) and the 07 engine (full power spec).
Nano
#1263
If I get the discovery set I dont get the 07engine? How can you tell which is which? and where can I get the 07 sopec engine?
Cheers
Cheers
#1264
CRF.21 off-road engine running
http://www.rcmag.com/modules.php?nam...=149033#149033
#1265
nano,
i need help with my old wasp. problem is it tend to overheat no matter how u tune it. the highest i experienced was 160oC which makes me so worried. i tried everything, Mixture 1/2, LSN 4.5, HSN 6. with this setting, it runs ok for the 1st few rounds, with very lean LSN, but then temperature shoots up after a few round. i spent around 2 weeks tuning this stupid engine. do i really need to buy those upgraded new parts in order for this engine to boost???? coz its driving me crazy with this engine.
here are my clutch setting
Clutch Gap : 0.3
End Play : 0.1-.015
Clutch Spring : KFactory 1.8mm Hard spring with less coil
Car : TM G4S
Clutch Shoe and centrifugal : Stock with 2 weights each in the ufo
Spring tension : 1.2
Plug : OS 6
if nothing we can do, i m thinking of selling it away coz i can't tune it. will replacing OS carb really help in this situation?
it would be appreciated if you could advise on the needle setting for me to fine tune a little, else, i m really stuck. thanks.
Clutch Gap : 0.3
End Play : 0.1-.015
Car : TM G4S
Plug : OS 6
#1266
nano,
Clutch Gap : 0.3
End Play : 0.1-.015
Car : TM G4S
Plug : OS 6
Clutch Gap : 0.3
End Play : 0.1-.015
Car : TM G4S
Plug : OS 6
#1267
Have you checked the exhaust seal? Or is there a leak in the carb or fuel or the pressure pipe?
#1268
CRF
CHANGE TO A #7 PLUG ,YOU NEED TO START RICHENING THE BOTTOM ONE MARK AT A TIME ,HERE IS HOW I RUN MY CRF ,YOU WANT TO START IT OUT WITH THE TEMP AROUND 198 DEGRESS, DO ABOUT 4 HOT LAPS IF THE RPMS STAY UP WHEN YOU COME RICHEN THE LSN FIRST THEN DO THREEMORE HOT LAPS, AFTER YOU SHOULD BE AROUND 225/230 AGIAN GO TO A #7 PLUG.HOPE THIS HELPS.SORRY GUYS BEEN AWAY FROM THE FORUM,JUST MOVED INTO MY NEW HOUSE.
#1269
Uniquexme, I think that your main problem is that your clutch setup is all wrong for this engine.
You need a very hard spring like the crf one, also with the crf parts I was using 0.5 gap and 1.9mm preload.
I am sure that your clutch is sticking way to early or working in a way that puts load on the engine at the wrong rpm range. This will overheat the engine very easily and make it impossible to tune.
Nano
Nano
#1270
Nano
Nano
#1271
uniquexme - hey, did you try tightening down the kfactory black spring to 1.6+. I have the kfactory setup too, but I have not ran the car yet due to school work and etc. I really like to know if the ufo clutch works with engine =).
#1273
Also bear in mind that because the CRF spring is longer, on the G4, I had to use a 0.8mm spacer between the flywheel and flywheel nut to lengthen the distance between the flywheel and flywheel nut extremity, otherwise you can screw the adjust nut on the flywheel nut.
Nano
#1274
Nano
if i using orion spring i need tight how many (mm),now i tight 1.0mm only,enought or not
#1275
