Team Orion CRF Wasp Rev X-Dyno results
#1126
Just back from the Euro B's. At least one CRF wasp in the A main i knew about built and tuned by Adrien Bertin. The engine looked good but the grip roll was bad so no chance to shine
Thanks to Adrien for the new Conical monifold and the new carb restrictor, it made a real difference to the low end power
Cheers
Cheers
#1127
Originally Posted by johnhsp
is no 110-120F is 110-120C,u mean wasp can run hot then other engine? i afarid boken my engine
At the Euros I started mine in the pits 7 mins before i went on the track and it sat ideling without missing a beat. 2 blasts to full revs and it was on song from the word go.
#1128
I drove 5min50sec before refueling with my CRF 2007.. and temp was around 125C and HSN is 2.5 turns out..
I really like my CRF 2007.. if gearing is correct you're at the tail of fast 1/8's
Nano, two of my friends burnt plugs and a small wire particle scratch piston and liner.. They were using orion CRF medium 6 plugs. do you have any ideas about it? I know they don't drive with so high temp's..
Asil
Asil
#1129
I have the following in limited stock, anyone interested can drop me a PM.
ORI81357 CNC Combustion chamber
ORI81358 Big Carb inlet
ORI88550 Double fuel inlet
ORI88008 ABI In-Line Pipe+Manifold (Hi-Speed)
regards
regards
#1130
I'm also back from the ECB and I was in the semi.
Engine was crazy fast after Adrien gave me the new pipe and the venturi. From that moment the power was very linear and easy to drive.
It's sad that my tire set was very bad and my pit man forgot to refuel one time.
Mark had the problem that he had traction roll in every corner in the final. I spoke to Adrien and he didn't have a clue why. In the semi all was good.
#1131
I watched your final and the engine was flying. Shame about the pitstop. What were the needle settings after fitting the new manifold and venturi?
Cheers
Cheers
#1132
Team Orion has in all the new engine CRF parts, except for the CNC back plate. As of last week, it wasn't available yet.
#1133
Well, I couldn't say
Adrien Bertin tuned our engine. But he hadn't to change the setting after installing the new venturi.
Tuning after the new manifold is not a good fact because at the same time he build a new clutch for us
PS: Well the pitstop was not the problem, the problem were the tires! After about 10 minutes I had no grip in the front and my medium time went from medium 15sec to medium 16sec
#1134
Installing the option parts will not throw of the tune, once you have the engine tuned right with the original stuff, you will always be very close to that point.
As I said before, the LSN and spray nozzle we basically never move from the factory position.
#1136
Originally Posted by GFIGUEROA
PUT THE O.S. CARB ON MY REV TODAY,ALL I CAN SAY IS WOW!STILL RUNNIG RICH,LOTS OF SMOKE.MODDED THE OS NEEDLE MADE HOLES LARGER FOR MORE FUEL.RUNS REAL GOOD .PUT 2 TANKS THROUGH IT BARELY HIT 200F.A LITTLE MORE TUNNING AND THIS THING SHOULD BE A BEAST!
#1137
Originally Posted by MRX4-R03
Instead of running the o.s. modded h/s needle just use the orion h/s needle the holes are big enough..
#1138
#1139
already try os cab with orion high speed needle,but i think os hs needle better than orion
#1140
If so that is what I am running, it just seems you can lean the top more with the orion high speed needle..but as far as performance how do you like the carb..
