Clutch change?
Clutch change?
ok my problems is this
my current clutch system is a standard crank 2 shoe with wrap around spring there are 2 problems
i cant use high performance .12 engines such as a os tz 5 port as the clutch wont fit
and two shoes just plain sux no bite
ive found a 3 shoe clutch and flywheel for a standard crank
can i adapet this for a pilot shaft?
doesnt matter what carb either will fit
do u guys reckon its worth the trouble??
im running in a 4wd 1/10th buggy but i want to be able to run the same motor in a 200mm tourer? ideas, or help please. thanks in advance
