New Trinity X Stock motor.
#46
The stack length is .870. There is a groove down the center of the armature where the drill balance slot used to be. The groove looks like one triangle part of a X....hence the name.
Most all of the ones I have built have been around 28-29000 rpm at the 5.0 torque step. Which is pretty close to what a roar stock was. But the wattage is for the most part 140-145 at the 9.0 step. Thats about 5 watts higher than most Roar stocks were.
EA
EA
#47
A buddy of mine picked up a few Ea's last week.. he ran his for practice and said it is the shiznit.. Normally fast guys starts about 6.7 and end around 7.1-7.2 or so.. he said this motor started right in the 6.7 range, and at the 6 minute mark he was still pulling 7.2's.. Said it didnt fall of at all..Looks hot so far..
365 foot tri oval, banked asphalt track.. with cap tires..
#51
Difference Between The Monster,ROAR and X Stock
Due to some confusion, I'll try to describe the difference between the Monster, ROAR and X Stock.
The Monster and Epic/Roar stocks utilized the same lamination. If you look at the lamination profile, for lack of a better term, it has a 'shark fin' profile at the center of the crown. The differences are:
-Monster Stock has a 40 lamination arm, with a .275" gap between the upper and lower segements.
-Epic/Roar Stock has a 36 lamination arm, with a .325" gap between the upper and lower segements.
-The X Stock utilizes an entirely different lamination profile. In laymans terms, the 'Shark fin' is more pronounced, with a deeper and wider recess behind the Shark Fin...more material has been removed. Also, the tips of the laminations are .010" closer together than the laminations used in the Monster/Epic stocks.
Jeff Cuffs has been testing this for quite sometime, and I believe has posted his on-track results...
Hope this helps eliminate some confusion.
Regards,
Todd Putnam
Putnam Propulsion
www.putnampropulsion.com
Regards,
Todd Putnam
Putnam Propulsion
