Tub Cyclone `S`
#649
http://www.gearchart.com/index.cfm?f...n=chart.create
#650
wanna run a stock class racer
My RC:
This is Cyclone S! in coming event, a good upgrade would be to get parts of the pro 5/6cell packs battery, high end-motor and some alumum parts for my sweet Cyclone 'S' (MOD SPEC).
#652
MD, thank you! I JUST wondering if universal part of any ae, serpert, corally, losi's SWAY BARS can fit on Cyclone S? Because HPI PRO4's sway bars wont fit on Cyclone s.
See the aluminium purple shocks and nuts from HPI PRO4 that I put parts on cyclone s.
#653
Some of the parts are from the Pro 4. The "C" hubs and steering knuckles are pro 4 parts among others. I don't know if Losi sway bars will fit, but I doubt it. Sway bars are not too expensive. I don't know if you're considering running any of the HPI/HB Challenge Series. If you are they have a box stock and rtr class for the Cyclone "S" and Sprint 2. You may want to take a look at all the classes. If you run the box stock class, options are not allowed except for tires and bodies.
#654
I bought the small cut-off wheels from walmart, about 15 bucks.
I removed rear bumper and cut tail off. It prevent from break or crack if my rc car's rear bumper hit on curb/ wall so hard or bump to hit car's rear bumper on pavement/ street so hardly.
I hope this solve issues.
#655
I will look the sway bars online for my cyclone 'S'. but I notice in USA, the Cyclone hop up parts is hard find right now. I hope to find the sway bars and hop ups somewhere in USA.
#656
Farbes - One way I've used to find parts is to simply Google the part number. You usually have to use the manufacturer prefix like HPI or HB before the number. Tower carries some Hot Bodies and HPI hop ups, also Stormer hobbies. I have the sway bars, but I don't remember if I got them from Tower or Stormer or some place else. That's what happens when you're a senior citizen. One of the easiest ways is to call your local hobby shop and see if they can order it. Just give them the part number. Sway bars are not too expensive. Good luck. I like that Dremel attachment. When I bought my Cyclone "S" used, the bumper had been broken off and a corner of the chassis with it.
#658
Guys,
Have anyone tried to use a Tamiya front one-way on Cyclone S? Do they actually fit as they just seem to be almost the same?
Thanks!
Thanks!
#660
The plastic pulleys will strip on the first meet (unless you are running something really soft like a silvercan 540 motor).
Upgrading the pulley you will also need to change over the centre shaft.
