Which charger is better- ICE or Cell Master
Hi all, I m planning to get a new charger to charge my GP 3700 batteries, which of the above is a better charger, have less know problem, more reliable, easy to use or any other recommendation which is around the same budget?? Please do NOT compare the discharge function as I use a discharge tray. Thanks in advance.
I was debating the same, ended up with the Cell Master, and I'm more than satisfied...
I have had both chargers and both do the job well. I chose the cell master because my packs just always seemed to get a better charge. It is also back lit which is a huge plus. And before you say it, I had the back light kit on my Ice. The only advantages that the ICE has are motor run in (which I didnt use) and price. I dont think you can wrong with either though.
I never had the cell master but the ice has worked great for me the price is why I got it.They both are good if money is a issue the ice is the best way to go. no way to lose both are good
I am happy with the Cellmaster. Very easy to set up and use.
Thanks...but according to my LHS, there were some batch problem with cell master when they were mass produced.....not sure what kind of problems......any one face with such issue? So far, only have good reviews on ICE.......
I wanted an all-in-one unit and went with the new Team Orion Advantage.
It does
-Motor run in
-Runs the comm lathe
-And is Lipo ready
So no need for another unit (ie motor master)
Its capabilities are the same as the Ice charger I guess, but I preferred going with a big name (Team Orion)
It does
-Motor run in
-And is Lipo ready
The Much More cell master is the better choice, IMO. It does not have the motor run in feature, but it does offer step charging and you can also run the warming tray and fan directly from the charger. The MM is more expensive, but well worth the extra money. You get a lot in a very small package.
If you are on a budget, the ICE is a very good charger, especially with the motor run in feature.
Trader Rating: 31 (100%+)
The ice has many features. Very good charger for the money. I like it alot.
Tech Legend
Trader Rating: 51 (100%+)
I have charged off both chargers and have not seen any performance differance on the track.
I do think the Much More is more high end looking overall and I do like the back lighting feature which I wish my ICE had. I happen to have ICE's but wouldn't have any problems using the Much More charger if I had the right deal on them.
