Blue bird servo glitching and shutting down speedy >
Old 04-30-2006, 12:06 AM
Got Xray?'s Avatar
Default Blue bird servo glitching and shutting down speedy
hi i have a brand new bluebird superspeed servo and it has been turning then shutting down the speedy then turning the speedy back on,i am using nosram Tomakawke reverse 18t speedy,epic 27t motor and helios with spektrum.
I have tried it with a different radio(jrxs3) and it works fine
Also all my stuff (servo,radio,reciever,spektrum,ESC) is all brand new.
Got Xray? is offline
Old 04-30-2006, 12:27 AM
burbs's Avatar
COULD BE A SPEKTRUM ISSUE.. Did you try the spektrum with a diff servo?
burbs is offline
Got Xray?'s Avatar
Default HELP!
HELP!
Smilies
Old 04-30-2006, 12:30 AM
Got Xray?'s Avatar
Yeah i was racing it with a standard jr and i have tried the servo with my radio with the standard reciever and module and it still does it,but when i use my friends radio hear and esc it works fine so it must be my radio
Old 04-30-2006, 02:19 AM
rampal's Avatar
Hi
Do you know if your speedo has a radio priority circuit? Seems that the servo is getting so much current that stops the speedo... just change the receiver and check what happens.... hope it helps
rampal is offline
Old 04-30-2006, 02:33 AM
milza's Avatar
Hi, i had the same problem and to fix the problem was to take the servo's supply wire staight to battery maybe not the best solution as the servo will wear quicker but its a fix anyway...
milza is offline
Old 04-30-2006, 03:45 AM
Its more than likely that the BEC in your reciever is not providing enough voltage to the Spektrum reciever, and its shutting down. Usually it can happen with QC2 ESC's though.
The fix is the spektrum plugin capacator that you connect to your reciever, contact Model Flight in Adelaide if you would like to buy one.
v0rtex is offline
