help please!!! tamiya super modified 11turns
i need some help "BADLY!!!!"
i have my tamiya super modified 11turns..
i got it 2nd hand..
i cleaned it and then i dont know the timing settings..
wether i will be on left or right or put it in middle...
if i will go to left what will be the effect
and vice versa on the other..
wat will be the effects...
tnx need help..
i got it 2nd hand..
tnx need help..
12 degree is the normal timing for most motor, if you run it vice versa the motor will run backwards, and when you tringer accelerate becomes reverse, means that you install the motor the wrong way, hope this help mate
some says if i adjust the timing it will be on tourqe?? etc??
im confused.!!!
hm.....................did the can motor have some measurement sticker???? my motor come out with measurement sticker -24, -12, 0, 12, 24 degree.
here some picture hope this picture can solve the problems
