Kyosho V-ONE RRR Evo
#1427
thank you ice_NL appreciate the good answer and the picīs
#1428
Originally Posted by rmdhawaii
Maybe Tim Johnson can help us clear this up...
BTW... How do you like that MEGA MF-12 MasMo? Any issues out of the box? How does it compare to the previous engine you were running?
I ran it for the first time last Sunday at our club race so i cant say much about the engine yet. The week before i ran the engine in and that went well. I can say it seems a lot quicker than my Vega V12-E engine i ran last year. I wanted to use the qualifiers to fine tune the engine but i had trouble to find a good setup for the evo and had some problems during them, in the first my diff cup got damaged so i didn't get an result, in the second the brakes weren't working and in the last one i had a reasonably handling car but my gears went of the car. So i had to run the 1/2 final, the setup of the car was good at that moment so i won that one. after that i had to marshal the next round and after that i had to run the main final. But i had to ask for a delay as i needed to change the shifting point of the 2 speed. I got a 5 minute delay but because of that i had to start from 11th place instead of 5th. but after around 7 laps i was leading the race and i won it with one lap on the 2nd car which was an mugen with a ninja engine. But next week i go to a bigger race so after that i probably know more about the engine's performance.
But when i had the diff problem i noticed the universals where an the edge of the diff, would it be a good idea to get some offset wheel hubs so that i can screw the pivot balls further in but maintain the 200mm width?
#1429
Spool?
Anyone know how to put a spool in one of these things instead of the oneway? I drive better with brakes. Is there a part I need to get? I am trying going to drive this thing for the first time next weekend and I would like to get this done before then. Thanks!
Scooty
Scooty
#1430
http://www.nitrokb.com/phpBB2/viewtopic.php?t=43
I can't remember what everyone else is doing since the Evo came out. Anyone?
#1431
The rears are good, i just screwed the pivot balls out and there still far enough in the cups. But its the front diff i have the problems with, last year i used a diff two times, and each time my race ended because of a broken diff cup.
#1432
Scooty
Scooty
Kyosho makes a nice and light locked front axle. Kfactory also sells a one-way/locked front as well.
#1433
Hi
Any recommendations in terms of servo choice for steering and throttle, as well as rx pack ?
#1434
Then you want the VZW219 Universals (47mm). The shaft is 2mm longer than VZW054, which is 45mm.
#1435
#1438
Thanks for the part number and picture. That really helped. I'm ordering one as soon as possible.
Thanks again.
Scooty
Thanks again.
Scooty
V-One RRR Lightweight Two Pieces Front Axle
KM-V3R-018 $16.50
Also will consider the light weight spool made Kyosho.
#1440
