Kyosho V-ONE RRR Evo
#2536
#2537
I got my sirio clutch from http://stores.ebay.com/Rdvtg-Hobbies for $74, he seems to be out of stock.. you're next best bet is http://www.the-border.nl but they're out of stock too.. it's hard to find.
#2538
Yep I was gonna post border but you beat me to the finish line
#2539
Quick question, is the servo saver supposed to be replaced when using a diff in the front ?
My servo saver is hitting the diff case, any ideas.
#2540
I have never used a diff in the RRR so i don't have experience regarding this issue...I'm sure you can use a dremel and trim certain areas so they don't make contract...hope this helps
#2541
Robert, if I dremel any of the plastic it's going to either make the diff leak or the push rods plastic weak, so thats out of the question, I just tried to replace the servo saver from either numbers it did not fix anything.
Another fix is to replace the balls with ball stud and use plastic ball cups that might fix it, but i find it hard that kyosho would over look something like this, anyone else faced this problem and has a fix ?
#2542
Looks like the ball end is the fix, looking over the EVO WC manual they replaced that item with ball ends. Will give it a try.
#2543
#2544
#2545
#2546
#2547
#2548
#2549
Hi Everyone.
I'm running the Plus 3 ct with the 3D clutch. Just wondering what clutch spring preload would be a good place to start ,for medium to high grip level.
Regards Paul
Regards Paul
#2550
