Graphite + Electronics Wire Question >
Old 04-26-2006, 08:24 PM
aN4rK1's Avatar
Default Graphite + Electronics Wire Question
hello,
I know that having your antenna wire touching a graphite surface is a nono but what about other wire? Like wires from servo/PT/motor? I want to zip tie a few wires to my chasis to make it look neat, can I do this?
aN4rK1 is offline
Old 04-27-2006, 12:37 AM
Superkarter's Avatar
I zip tie my servo and esc wires to the upper deckand no glitching issues
Superkarter is offline
Old 04-27-2006, 01:34 AM
wagonman72's Avatar
If you keep your antenna away from everything else you should be ok. I find that glitching is usually caused by something in the electrical system actually being damaged or faulty. Things like bad brushes, cold solder joints, bad crystals, bad servo/speed control plugs.
wagonman72 is offline
Old 04-27-2006, 06:37 AM
HotrodHopkins's Avatar
Trader Rating: 31 (100%+)
normally i use plastic twist-ties, or just take your wire and wrap it around a screwdriver tightly, it'll make it have a coiled affect.
HotrodHopkins is offline
Old 04-27-2006, 08:34 AM
aN4rK1's Avatar
thanks guys, my radio is a spektrum also, no problems there right?
aN4rK1 is offline
Tsquare's Avatar
Originally Posted by aN4rK1
hello,
That should be not problem, I zip tie my wires, then tuck them into the chassis. I've never had any glitching issues.
Tsquare is offline
Old 04-28-2006, 12:44 AM
I also do the same. Just keep your antenna away from all graphite and wires and you should be fine.
aston is offline
