Kyosho V-ONE RRR Ultimate Edition (UE)
#166
I have run about 1/2 gal of fuel since using them and have not seen any wear. I also run the front 18T.
#167
i heard that what the metal pulleys do is the belt wears them so that each 'tooth' on the pulley has a sharp point on it and then the pulley eventually cuts through the belt.
i have seen metal pulleys like this but they were a different brand. kyosho might be different but i still recommend you stay with plastic unless it is absolutely neccessary (like the 21T brake pulley)
#169
which alloy pulleys do you recommend i should get??
the kawahara ones or the kyosho ones ??
has anyone tried both???
#170
Double check the diff pullys if you get those in aluminum. They're a smaller size on the new car.
#171
Originally Posted by carkillaii
I've used Kawahara pulleys on my V1r and never had a problem with them knife edging, As for the V1rrr dont know the part# but I think they will work fine
#172
Originally Posted by rmdhawaii
Are all your pulleys Kawaharas? How many hours would you say you race a month and how often do you replace your belts?
#173
does anyone know the part number for the kawahara 21T brake pulley ??
#174
K-493B: http://www.hikarisystem.net/kawahara...oods_ID=K-493B
#175
This is really coming together nicely.
Spec has been updated: http://www.nitrokb.com/vonerrr/UltimateEdition.html
#176
thanks rmd
everytime someone asks a question your always there!!!
i know i speak for all of us when i say that you are a great credit to the v-one rrr and this forum. i know with you onboard the 3r will always stay on top of the rest of the competition
#177
with the database the kfactory brake disc is a bit wider on the inside and that helps to minimize the disc floating on the shaft.
and in the 3r x section on the 3racing throttle mixing arm you spelt your name wrong
your database is good stuff
is VZW207 a new part and would it be available yet ???
i am trying to bulletproof my 3r by purchasing the alloy brake pulley and skyline outdrives. basically im building an UE
#178
I dont know if i got a bad example of the KFactory brake disc, but mine differs about 0.15 mm in thickness resulting in pulsing brake. Also it fits very poorly with the brake hub since the hole is too big.
The glued brake pads is awsome though combined with the standard disc.
#179
il check mine when i get em
#180
Thanks!
