Tamiya TB Evolution V >
Like Tree143Likes
Old 05-13-2006, 08:20 PM
  #121
Originally Posted by Scuad X
Slightly changing the topic on this thread, does anyone know an estimate release or a possibility of a conversion kit from evo iv to evo v?
They are totally different car. Different bulkheads, carbon lower and upper deck, motor mount, ring gears, etc...
So no, there won't be a conversion kit.
trf_racer is offline
Old 05-13-2006, 09:57 PM
  #122
viet_mafia's Avatar
i highly doubt that there will be a conversion kit as its a totally new tb evolution with new bulkheads (new bottom plate) etc. etc., there's never been a conversion from evo 1 to evo 2, evo 2 to evo 3, or evo 3 to evo 4 so i don't see why they would start now....
I just wanna know what parts they'll improve on this evo 5 for the evo 5MS
viet_mafia is offline
Old 05-14-2006, 12:58 AM
  #123
Hebiki's Avatar
Trader Rating: 26 (100%+)
i know one of the bullet points (on the Tamiya site) is that the bulkheads are lighter than the ones on the EvoIV MS.
Hebiki is offline
Old 05-14-2006, 03:01 AM
  #124
TryHard's Avatar
Originally Posted by rcnewb2004
curious, most ppl want to make the evo V an indoor racer... just wondering... what makes this car more suitable for indoor than out door? I was looking at the specs on the tamiya website and it says it has a minimum clearance of 5mm... isn't that a bit high for minimum clearance?
Couple of reasons
1) it has the new short wishbones... which if the theory is right (that they are similar in length to the Cyclone arms), then they will the ticket for indoor (Most top TRF drivers seem to use either the cyclone or old TA04 arms indoors).
2) it's a shaft.... and given that current consensus is that shaft is best for stock , and on a par with belt in 19t, and given I won't run more than a 19t indoors anytime soon... should make it a bit of a weapon.
Regarding the ground clearence, I never run less than 5mm indoors, force of habit really, as a number of clubs I ran at had a rule in place to stop people chopping the loop given it couldn't be placed under the racing surface.
Ed
TryHard is offline
Old 05-14-2006, 08:54 AM
  #125
rtypec's Avatar
Bring some extra dough to the Reedy Race...you may (or may not) be in for a suprise
The Evo5 is going to be good.
rtypec is offline
Old 05-14-2006, 10:03 AM
  #126
Thx TryHard,
That sounds cool.
I am wondering does short wishbones = short dog bones... ? so lets say i want to use the LW suspension set instead, do i need new dogbones as well?
Do you guys think the EVO V will have any "future" in mod racing?
rcnewb2004 is offline
Old 05-14-2006, 10:38 AM
  #127
Patriiick's Avatar
in mod, i am not so sure to go after the top-top uber cars with super strong motors.
But its probably a great car for stock where you have less of a flywheel effect
Patriiick is offline
Old 05-14-2006, 11:19 AM
  #128
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
yes at the mo evo 4 runs 46mm shaft`s
will go down to 42mm shaft`s to accomodate new wishbone setup
MR JOLLY is offline
Old 05-14-2006, 12:26 PM
  #129
TryHard's Avatar
To be honest, I doubt it'll need new axles...
if (and it is a big one) the theory that the arms are the same length as the cyclone ones, then simply, I wouldn't have thought they'll change it. The cyclone arms are only 1.5mm R and 1mm F shorter than the current LWT arms, and given that the bearing spacing would still be the same, no need really
The TA04 suspension used short dogbones beacuse a) the arms were shorter, and b) the bearings in the hubs were further apart, and hence longer axles.
HiH
Ed
TryHard is offline
Old 05-15-2006, 04:59 PM
  #130
danjoy25's Avatar
Trader Rating: 38 (100%+)
Hopefully they use the same axles since i've got the ti version
It would be interesting if they include the motor heatsink and blue short turnbuckes for the stabiliser and the blue stabiliser ball ends as shown in the pics posted by Masa. Only time can tell. as they don't come standard in the MSX.
danjoy25 is offline
Old 05-15-2006, 05:06 PM
  #131
TRF415boy's Avatar
what are you on about, they all come with the MSX apart from the heatsink.
TRF415boy is offline
Old 05-15-2006, 05:20 PM
  #132
danjoy25's Avatar
Sorry about that. I got confused with the TA05 stabiliser set that I just got a few weeks ago. Its all good then. Hopefully we get the heatsink as well.
danjoy25 is offline
Old 05-15-2006, 07:18 PM
  #133
akuhon's Avatar
Dear all,
Interesting new chassis.
Could you mention all new improvement over evo IV so far (roughly by looking the photo only).
I still consider it worth to wait and later compare with the Yoke's LCG.
Thanks for the info.
akuhon is offline
Old 05-15-2006, 07:26 PM
  #134
Burlap's Avatar
Originally Posted by akuhon
Dear all,
The car seems to have a low centre of gravity. And a bigger number in its title
Burlap is offline
Old 05-15-2006, 09:19 PM
  #135
Guo Chean's Avatar
Dear all,
is more lower than LCG some more the upper deck is one piece more rigid than LCG 2 piece.
Guo Chean is offline
