Tamiya TB Evolution V
#287
Originally Posted by rcnewb2004
Is there any chance an Evo V can take a 112T 64p spur?
Originally Posted by Joel Lagace
How many screws need to be removed to access the front and rear diffs? Do any chassis or towers need to be removed? About how much time to get at them??
Man this car is hot!!! My SD took 2 screws for the rear and 2 for the front plus removal of the bumper
#290
Thx Bender!
I only need the car now.... should get one in a few weeks. Anyone got any building tips for the TB EVO V?
#291
can you use the clear diff covers for the 4 on the 5?
#292
Originally Posted by rtypec
I tried installing an Evo4 spool and it looks like it won't work regardless of all the combinations of spacers that I used. Booo!
#293
Originally Posted by Hebiki
this is what i added:
- Ti and Aluminum screws
- all electronics (obviously )
- RW Racing 64P 96T spur
- alum. spring retainers (cannot really see it from the pix)
the rest is KIT/BOX stock.
rcnewb2004... yes the gearboxs are sealed. spur gear is the only thing exposed to debris (i also race on a parking lot track).
Just going to add a few more bits to my order... can't wait to get mine now
Cheers
Ed
#294
nope. it will stick out below the chassis. 100T would be the biggest is my guess. 96T is already very close.
7 total. 3 for the gear cover and 4 for the bulkhead. (front and back). if you dont run the gear covers, then just 4 screws.
cheers, looks like i need to pick up a 98 or 96 spur.
Ed
#295
Originally Posted by TryHard
really should read your other posts first... DOH!!!!
Ed
Ed
the car comes with two spurs.. 90T and 96T. crappy plastic quality though. so i threw in a RW Racing 96T spur right off the bat. The other went to Rod C... when he started to build his.
jhigga15.. i ASSUME that it wont fit since the evoV has a lower COG and the bulkheads sit lower. so the covers might be too tall.
#296
I don't see why not.... it's something I'll give some thought too... thanks for the kind words over the current one (still meaning to finish off the tips section, not done yet... oh well)
Just had a thought, with my new job, i have access to loads of facilities to do a pucka job on the chassis for this car.... I even have access to pre-preg carbon to build stuff, and mould making equipment... Mwhuaha!
Cheers
Ed
Cheers
Ed
#297
Just had a thought, with my new job, i have access to loads of facilities to do a pucka job on the chassis for this car.... I even have access to pre-preg carbon to build stuff... Mwhuaha!
Cheers
Ed
Cheers
Ed
ill have an editable EvoV set up sheet soon. i have a 415MSX one if you want it for your site.
#299
Spur and pinion protection
For those who are parking lot racers, or who are just concerned with spurs and pinions being chewed up by rocks and such, i found a very simply method which saved many spurs gears from death I've done this for more than 2 years now.
Just using scrap lexan from your body and mounting it on the screw next to the spur gear. I too race in parking lots and found that this saved my spur gear dramatically, probably reducing 98% of all rocks entering the danger zone
Here is my example on my evo4MS:
#300
good Idea
