Speed Gems 2 Jade Can It Have Timing Adjusted
Can I adjust the timing on my trinity speed gems 2???
if so how and how much??
Loosen the two siver color screws on end bell. They are the ones between the positive and negative terminals. rotate the endbell, counterclockwise untill the line on the can is between the first and second line on the side of the endbell. That should but you at around 18 degrees of timing, plenty! If your not racing, and want your motor and brushes to last, keep the timing lower.
