Your thoughts on "Slow is fast"
I was able to qualify for the B Mains at my local track this past race weekend, but I had to do some very aggressive driving to do it. I took someone's advice and tried to stay "on throttle" through the turns (letting up a bit of course), but I found that I had to really anticipate when to turn (i.e. turn early), to clip the turn at the correct point. If I judged a turn wrong (early or late), things would get a bit messy. The car wasn't setup for this type of driving, but I have a pretty good idea of what I need to fix. Overall, I had a lot more fun driving this way.
Afterwards, a buddy of mine at the track said that I was too much on the throttle. He reminded me that "Slow is fast" - which I fully understand, but when I drive slow (i.e get completely off the throttle entering a turn and then accelerate out), I'm too slow. Because we have a very tight track, with 12-16 turns depending on how it's layed out for the day, driving fast isn't so easy. I realize that any mistakes cost time, but I would rather try driving fast and get in the B Main than drive slow and qualify for the C/D Main. My thoughts are, that I can always work on my driving and throttle control.
Am I taking the wrong approach? Do you guys take the "Slow is fast" approach or do you stay on throttle?
I'm still very new at this (4th race), so I could use all the advice I can get!
Thanks!
Thanks!
i think the term should be"smooth is fast". overdriving is the problem most people have in races. get to the track by yourself and drive around it as slow as you need to run the best line. the more you practice this way the faster you will be able to get around the track. on race day never race the other cars. run the line that you learned while practicing and you will be faster than before.
Practice as much as possible and you will get faster over time you can't come out to a track expect to be as fast as someone who puts in long pratice hours or someone who been racing for years from exprienece it takes time that why tracks have different classes to race and A -D mains etc.
For some of us, we don't have a permanent track to practice on. The parking lot we race on is not available till race day. I find it hard to practice else where. The conditions are not the same.
For me "slow is faster" most of the times. Too slow is not to good. There are times when you got to step up your drivng and get aggresive.
when you negotiate a turn, you must do it with the least possible distance travelled and the smoothest. I found out in my driving if i just get every corner very well, i get good laps. i also try to as much as possible not to use too much brakes.
most of all, it's in your set-up. there's a guy in my track who set up his car such that he can throttle on corners and still travel the least possible distance. He actually has the fastest lap time in our track. Our track is also very technical.
Originally Posted by Ivan Dickson
So do you ever race major events?
It'll cost alot for me to travel to the mainland to go racing to attend major events Can't drive there, have to fly. Living in the middle of the pacific has its disadvantages.
Years back Robert at Ashford gave me these two pieces of advice:
1) where you are on the track is a lot more important than how fast you are going
2) tires win races, motors lose races
Those pieces of advice have helped me a lot.
Tz
Tz
hey I think that "slower is faster"is the best thing that happen to my driving skills. I would take my throttle down to about about 80-85-90 percent. Then i would try to stay on the "fast line" believe it or not my lap times were the same as when i was at 100%. My line was so much smoother. then we i hgot the hang of the line i would turn it up and just try to drive the line and not to try to hard to drive it fast. so i think"slower is better"
A car that is well set up will dictate how fast and smoothe you get around. Its typicaly a long list of every thing working correctly including the traction, sun, temp.,ect.etc..........
No, I haven't. Would like to race a major event, but I'll probably get in everyones way.
I think when everyone on a small technical track race "slow is fast" with smooth entrance and exits you can have a good race. But when you get my son racing with you (he's 15) that race's in a style I call "out of control but in control" he is impossible to beat. I know its because of his super reaction to what the car is doing. If he hits a corner to fast and the car goes loose he can quickly react to that condition and still haul a_ _ through the corner. I consider myself a "slow is fast" driver but when we are in the same heat and I'm racing my butt off and see him coming up behind me I tell myself and sometimes say out loud "your not getting by me" he will throw that car around me like I'm standing still. BTW he got first, I got second for the season at Hobbytown USA parking lot races in Minnetonka MN. So I believe "out of control but in control" or aggressive driving is the fastest way around a track. It is hard on tires so a balance of smooth and aggressive is needed at long races.
Thanks guys! You've given me a lot of good advice and ideas for the next race.
