Serpent 720
#646
Originally Posted by Luke W
The Futaba S9451 digital is fast, has lots of torque, and will last...I've had mine over a year. They cost about $80-$90.
#648
Try the jr z8450 i have it on my steering since i have my first impulse
#649
The missing springs seems to be a Worldwide issue. I was given a set when I picked up the car so it wasnt a problem. Anyone who gets one needs to check to see if the springs are in the kit.
Finished the build last night, it is pretty much what I expected. I must admit I think I prefer the 710 front & rear belt tensioner set up. The 720 lay out for the eccentric carriers is a bit of a pain. The rear plate/upper bulkhead piece is also a bit tricky to install. Looking forward to hitting the track with it tommorow night. I was very happy to see all the upgrades from the 710 fitted with no hassles, saves a heap of coin having to buy all the bling bits for the new car.
#650
Looking forward to seeing you run around at the Worlds 2006 with the new unit Socman!!!
Cheers The OX
#651
Three the hard way
serpent 720 and the rest of the Crew
#652
Hi,
here you can find my new 720
I am shure you also will like the new car!!
see you!
Daniel
see you!
Daniel
#653
#655
Originally Posted by GrandeGixxer
Do the aluminum hexes come standard with the 720? I like the way the radio tray goes all the way to the front shock tower. Should stiffen the front bulkheads quite a bit.
#656
Originally Posted by going4#1
It's what I use and it's one solid servo. Used to use Hitec but after the fourth one melted down went to the Futaba 9451 and haven't had a need to change yet.
#657
Orange alu hexes are standard. The purple ones on my photos earlier in this topic are not standard...
#658
I'm using a Hitec as a steering servo. Have been doing so for the past year and a half, and have had no problems whatsoever with it. So it's not all bad...
I have used graupner and futaba servo's for throttle/brake though and destroyed 1 graupner and 1 futaba so far. Braking is very bad for the servo...
#659
The 720 is quit light!
Only 1735g with bigger tires and pers. transponder.
Thantīs great
see you!
Daniel
Thantīs great
see you!
Daniel
#660
fried engine
Hi guys,
It looks like I fried my engine yesterday. Couple of reasons I can think of:
- Hot weather + 35 C
- Small cooling head (didn't have time to buy the new larger one)
- 1st gear was shifting about a sec too late, we were trying to adjust it before the engine blew :-(
- Track is really fast, has a long straight where you can push the engine all the way up to the limit.
Situation on the engine is following: It blew right at the end of the straight. It just made a silent tsssss (like a snake) before it went dead. Car was very hot at that point. I waited like an hour for it to cool down completely. Then I restarted it. It starts without a problem but after 10-15 sec it stalls again.
Now the question is: Will it be enough for me to just buy a new piston and sleeve set? Or what else should be changed? Or is it enough if I just polish the pieces that have been fried? Maybe dumb questions, but first time with a dead engine and just looking for some help here as a loyal Serpent fan and driver.
P.S.: Greetings to Tomaschko and Kandi, looking forward to seeing you here with the new 720 asap. Alles klar?
